Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: aerial on the tig
    Oct 2009
    aerial on the tig
    Hi Guys,
    Does anybody know if you can purchase a smaller aerial than the standard one that comes on the tig (103tdi)
    I often use a car cover to cover it up when its hot but have to unscrew the antenna to avoid bending it.
    Also, sorry - the "coming home" headlight feature, I have it switched it to stay on for 20 seconds when you lock the doors, but the headlights dont actually come on.
    I read the manual but cant find why they wouldnt come on.
    Saying that, when I unlock the doors (remote key) the headlights come on...
    Jun 2009
    The Sharan Arial replacement seems to be the best bet.
    These can be sourced from anywhere on google really.
    Just screw the old one off and screw the new one on i believe.
    I don't know about the coming home feature.
    Might have to look at some vagcom changes for that one.
    Point Cook, Vic
    Quote Originally Posted by Ivica View Post
    Hi Guys,
    They are currently available from the Dub Addiction website for $29.95 inc GST and free postage. A popular upgrade on Tigs that need to get through low garage doors as well
    http://www.dubaddiction.com.au/index...products_id=21
    Seems to be a common problem with these cars as a few of the dealers around the country have even started ordering them.
    FOLLOW US ON FACEBOOK
    Jul 2009
    You will need to flash your headlights once after you turn the ignition off. When you open the doors, the lights will come. It's in the manual.
    Dec 2009
    Casino, NSW
    Hi Guys,
    Re the "coming home" feature; it took me ages to work that one out.
    When you get home and turn the vehicle off, you need to flick the left-hand light/cruise wand towards you before you open the drivers door. You will see the headlights flash and then when you open the door they should stay on for the pre-set time.
    I had expected this to be more of an "automatic" thing that would kick in when the sensors detected low light but, when you think about it, it makes more sense the way they've set it up.
    Cheers,
    Luke
    Dec 2008
    Alexandra, New Zealand
    All correct HOWEVER if you have auto headlights and your garage is dark enough to trigger them (as mine is) then it works without having to flick the lights I think (now I've said that I'm not positive but I am pretty sure !!!).
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2008
    QLD
    I have auto headlights (I thought they were standard - but maybe came with the comfort pack?), but mine have only ever worked once. I don't know if I accidentally flicked the high beam lever or not. Now I know that, I'll try it out though.
    Oct 2009
    Thanks guys, legends !!!
    I will test the coming home lights feature tonight
    Thanks heaps Tim on the antenna - I will definetly order one.
    May 2009
    Quote Originally Posted by mickofoz View Post
    Thanks very much. so simple and so good. I wondered why the feature didn't work for me - who would have thought of reading the manual
    Maybe this should go in the quirks section to help our other non-readers?
    Apr 2009
    Canberra AUST
    I thought I might be able to source this stubby / Sharan antenna locally...
    but no luck?!?!?!!
    Tried going to dubaddiction today to order one via them - but their website seems to be down?!?!?!
    (mmm is it actually an antenna or an aerial!?!?!? And is there a difference?!)
    2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
    Delivered 22 May 2009
