Hi, i have a Tiguan 2008, 2.0 tdi 140 hp, and i have some problems, 2 days ago when driving i got 3 yellow errors on dashboard : ABS, ESP and tyre pressure and parking sensors stop working from that point. I did a scan with vcds and i got this errors :
VIN: WVGZZZ5NZ8W010479 Mileage: 259080km/160984miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 016 J HW: 03L 906 022 G
Component: R4 2.0l TDI G001SG 9979
Revision: --H01--- Serial number: VWX7Z0GN3NC1W4
Coding: 0000172
Shop #: WSC 39918 136 13308
VCID: 3979CB6F70AC49D693D-806C
1 Fault Found:
049448 - No Communications with Parking Brake Control Module
U0128 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 60
Reset counter: 255
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:30
Freeze Frame:
RPM: 874 /min
Speed: 38.0 km/h
Temperature: 20.7°C
Voltage: 13.76 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Temperature: 38.7°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 G HW: 5N0 614 517 G
Component: J104 C2 450 V2 0005
Revision: --H11--- Serial number: 00000000718229
Coding: 0011551
Shop #: WSC 01324 785 00200
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 30
Reset counter: 103
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:30
Freeze Frame:
Speed: 39.0 km/h
Hex Value: 0x00AD
Voltage: 13.75 V
Bin. Bits: 00011111
Count: 205
Hex Value: 0x0000
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 B HW: 1T0 919 475
Component: PARKHILFE PLA H07 0006
Revision: -------- Serial number: 22030728501446
Coding: 010002
VCID: 3A7BD463B5AA42CE9A7-806F
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 103
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:30
Freeze Frame:
Temperature: 21.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 56
Reset counter: 103
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:30
Freeze Frame:
Temperature: 21.0°C
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 5N0 920 870 D HW: 5N0 920 870 D
Component: KOMBIINSTRUMENT VDD 1220
Revision: V0004000 Serial number: VWX7Z0GN3NC1W4
Coding: 0007104
Shop #: WSC 00011 888 96745
VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 68
Reset counter: 103
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:30
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H06 0052
Revision: H06 01 Serial number: 311007F2001677
Coding: F9A37F460016036002
3 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 142
Mileage: 258610 km
Time Indication: 0
Date: 2000.00.00
Time: 12:59:11
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 210
Reset counter: 255
Mileage: 258610 km
Time Indication: 0
Date: 2000.00.00
Time: 12:53:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 53
Reset counter: 103
Mileage: 259010 km
Time Indication: 0
Date: 2000.00.00
Time: 10:33:31
Address 53: Parking Brake
Cannot be reached
Address 56: Radio
Cannot be reached
End
Can someone help me?
