Results 11 to 20 of 23
Thread: 60,000km service on my Tig....... well well.....
    Jan 2011
    Brisbane - QLD
    Automatic torque converter yes. DSG actually no, it slows down the car like manual as it downshifts to lower gear.
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Erskineville, NSW
    Most dealerships will be extremely conservative when it comes to brake replacement recommendations. If they think you won't get to the next service then they'll recommend replacement. I can see their point but it adds a lot of expense to the customer that might easily get another 10,000km of usage out of the pads.
    On my 125,000km Octavia that is fatter than a GTI but lighter than a Tiguan the brakes are F6mm & R4mm. I can't quite see how they could wear at twice the rate so I'm assuming the dealer is getting greedy.
    Aftermarket dustless pads & higher quality rotors FTW!
    Apr 2010
    Geelong
    Didn't know the Tiguan is that much heavier than a GTI. Would definitely wear the brakes faster then.
    I can't see how an automatic car (DSG included) would wear brakes faster. The DSG certainly slows the car with the gearbox.
    2010 Mk VI GTI-Red/Manual/Detroits/Park assist/Leather/MDI/Sunroof/Bi-Xenons/Chassis Control/Elec Driver's seat/5 Door/Tint
    2009 Triumph Street Triple R Matte Blazing Orange
    1971 Mini Clubman GT
    Sep 2011
    Townsville, Nth Qld
    Just had my 45k service and my brakes still had 90% left on the front and 60% on the rear, which was a pleasant surprise - although seems odd that rears more worn than front?!
    Sent from my PadFone 2 using Tapatalk 2
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Sep 2011
    Townsville, Nth Qld
    And you guys are lucky you don't have a DSG otherwise you'd also but up for ~$600+ (dealer price) for new DSG oil.
    Say whaaaaat?!
    Have to save up for next (60k) service I think
    Quote Originally Posted by Tiggy1 View Post
    I've heard rears are softer material
    Erskineville, NSW
    If the Tiguan is the same as an Octavia (probably is) then under light braking the rears come on earlier than the fronts to reduce the severity of the nose dive. If you tend to use your brakes sparingly (eg: you read the traffic flow & tend to coast up to the lights rather than rush up & brake at the last moment) then the rears will wear quicker than the fronts. I'm at 125,000km & the fronts are about 80%, the rears 40%.
    Sep 2011
    Townsville, Nth Qld
    Wow - brakes set up to reward good driving, cool
    Jun 2009
    Melbourne Vic
    What's with Tiguans an rotor replacement, or any new car for that matter, what happened to machining discs, can't think of any car that I've had that needed the disc rotors thrown out and replaced with a new set before being machined, new pads yes but not new rotors, are the vw disc so thin to begin with?
    Having said that my independent VW/Audi mechanic told me at the last yearly service I would need new discs soon,WTF, I courteously declined and said I would get back to him when needed, plenty of meat left in the discs, just had last yearly service last month to break down the costs of pending 60,000 service probably due in a couple of months again rotor replacement mentioned(actually I brought it up) but still a fair bit of meat left in the rotor, am I missing something or are modern car rotors junk to begin with?
    Erskineville, NSW
    Quote Originally Posted by cubes View Post
    Standard for a Euro vehicle. Mercs, VWs, Volvos, etc have been like that for 40 years.
