I'm guessing you've looked at the various online wheel configurators to pick these sizes out.
One question (which doesn't apply to Aussie delivered Tiguans) is whether you have any body kit on your car. Reaseon I ask is that will effect what width/offset you can handle without haveing your wheels extend beyond the arches.
If it's standard wheel arches (flush with the body) then I think you're around the mark, though I'd double check before making a purchase.
Most of us haven't gone as wide as 10" so you'd be on your own as far as clearance.
Also I'd be looking at what tyre options you have available in both sizes as this may sway you one way or the other.
Also make sure whatever wheel you buy has the currect centre bore (57.1mm) and bolt hole PCD (5x112)
