Results 1 to 10 of 16
Thread: 155rline Tiguan performance mods
    Jul 2015
    Manly
    Hi guys,
    So last week I sold my beloved golf R32 to move onto the new Golf 7 mk7.. Well that was the plan then due to an expanding family a Tiguan was required.
    So we take delivery of our 155 Rline on the 25th of July
    Im after doing some mods but have some questions first.
    I want to do the APR stage 2 kit but I'm not sure if the down pipe fits the 2015 and also want to lower it about 30-40mm.
    Does that affect the active chassis control?
    Has anyone modded a 2015 155, if so what have they done and what sort of power are you getting?
    Like
    Cold air intake
    Down pipe
    Cat back exhaust
    Full exhaust
    ECU flash
    Lowered Suspension
    Bi Xenon Headlights
    Folding mirrors
    Mar 2015
    Torrens ACT
    Went down the stage 2 + thingie with full suspension, gearbox software, steering arms - HR sways, HPA shox and more with my GTI.
    We have now replaced it with the R-Line Tig.
    It is my wife's car and she and I love it.
    I almost enjoy occasionally driving her R Line more than my Audi SQ5!
    You stand a good chance of screwing up a surprisingly good deign if you go down that list, almost needlessly.
    The Tig handles better than the modded GTi and I'd advise to leave you to leave it alone.
    There are some on this forum that seem to want to do nothing more than fiddle with otherwise good engineering - they exist on all the forums and its horses for courses.
    We have done APR Stage 1 which is more than enough - downpipes, exhaust etc is not Tig style of motoring and you never will get a worthwhile return on investment as it is already extremely well sorted.
    Stage 1 APR gives quite sufficient and 90+ percent of what the rest of the noisy and expensive other bits will get you.
    Just APR 1 and leave it alone - be patient and you will soon see why.
    Dingah
    Jul 2015
    Manly
    I'm glad you talk about it almost being as good as your SQ5, I was going to get one but at the end of the day couldn't justify the extra for my girlfriend, who really doesn't mind what she drives.
    Are you happy with the stage 1 over stock?
    Appreciate your input
    Jun 2013
    Here is my 2 cents. If you are missing your R32 and really need to tap in to the full potential of Tig go for K04 upgrade. You may say I am biased because that what I have but if you could drive one with 365 Hp with ~ 500 Nm torque you will be pleasantly surprised. Almost everything in that Tig ready for that sort of power except suspension setup. So lowering spring or some high quality coilovers or a cupkit will sort that out.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Jan 2011
    Brisbane - QLD
    my approach to mods is drivability and lap times (not relevant to tigs unless you track it).
    my tig is all stock but i find it sufficient for day to day traffic. but once there an open space, to accelerate quickly up.to.the posted limits can feel.sluggish (>1500kg is not light).
    i actually drove my tiguan on a race track at lakeside raceway first week i got it, it felt very good for a SUV and from then i left it stock.
    but if i do go with modding it, improvements could.be made on braking (mainly higher temp fluid), better tyres (had touring tyres bridgestone sport dueler in 235 50 1, stg 1 tune and rear sway bar.
    Sent from my GT-I9506 using Tapatalk
    MINI Cooper S Clubman - FWD
    Mar 2015
    Torrens ACT
    SQ5 is a different concept than Tig - it's about luxury sports and being totally competent at everything; torque galore and excellent performance with little overt manifestation. Much higher quality than the Tig, more room and heavier footprint.
    After all the SQ5 is more than double the cost of the R-Line Tig so it naturally brings expectations which it delivers on.
    The Tig is smaller with Golf roots - but when parked next to the Audi it appears to tower over it as it is so much taller - hence the higher fuel consumption.
    It does not manifest any sporting roots but the suspension set up on the R-Line is extremely good and it makes for a more agile platform that feels and of course is, smaller than the SQ5.
    Stage 1 is quite adequate and remains in character with the rest of the Tig platform.
    Nice balance between power, acceleration, handing and braking.
    If you were to try and graph bang for the buck and look for the sweet spot APR Stage 1 on the R-Line is about right - adding even more power, screwing around with suspension and handling, bigger brakes are unnecessary additions where the costs outweigh the benefits.
    Dingah
    Quote Originally Posted by Athan View Post
    Arrawarra
    Quote Originally Posted by Dingah View Post
    ... but the suspension set up on the R-Line is extremely good...
    Dingah
    Just curious, but does the R-Line have any different suspension components to the rest of the range, or for that matter, earlier models?
    I thought my car (base 2010 model) had a little more body roll & front-to-back see-sawing with the stock setup than with the mild lowering i currently run with Eibach springs. Much prefer the flatter cornering/accelerating/braking. Still on original stock shocks & getting good tyre wear as well.
    Mar 2015
    Torrens ACT
    155 R Line has the electronic adaptive chassis control.
    Dingah
    Jul 2015
    Manly
    Dingah
    Is it a problem if I lower it? Say 35mm
    I'm not sure on this one though I think you have to be a bit more careful. Suggest having a look at what the Golf/Scirocco guys do when they have ACC. I believe there are coilover systems which are compatible with ACC, however not sure if there is anything for the Tig.
