Just an FYI - I can confirm that an iPhone5 with the 30pin adapter works in exactly the same way through the MDI interface and RNS510 as my old iPhone4 did.
So the rumours that the 30pin adapter wouldn't work are untrue.
Please post all IPhone related Q & A into this thread. We don't have to have 100's of IPhone related threads. It will be easier to find the answer you're looking for.
You can also use stickies as there may be the links to some informative threads from the past.
Thank you for complying.
MY11.5 Golf R - Candy White 5 door - still giggling like a child when I drive it!
The title says it all. I've tried a few times only to keep getting a "pairing unsuccessful" message on the phone.
The BT unit is a 9W3, and I'm using the 0000 PIN. I tried a search, but type "iphone 5" into the search box and see what comes back. Any help appreciated.
EDIT: Problem solved. The iPhone PIN is 1234 not 0000.![]()
