Results 1 to 10 of 12
Thread: where to tap in forsub amp on 6r polo RCD510
LunchboxVRS where to tap in forsub amp on... 15-07-2012, 08:30 PM
readerr0r Speaker Level only, you can... 15-07-2012, 10:45 PM
LunchboxVRS Will this only affect the amp... 15-07-2012, 11:03 PM
readerr0r My bad, thought you were... 15-07-2012, 11:48 PM
LunchboxVRS im going to change the... 16-07-2012, 09:41 AM
ranton-inc Pm user glidn he does all... 16-07-2012, 04:42 AM
CptFS If you don't mind me asking..... 15-08-2012, 02:43 PM
CptFS Correction to that.. What... 15-08-2012, 03:48 PM
    May 2012
    done a search but found nothing i could use.
    I have a 12.5 polo GTI with RCD510. im putting in a sub and amp and need to no the best place to wire in for sound.
    is there a mod to attach RCA's? also im going to install a RNS510 very shortly so am i better of waiting till i put it in or can i tap into the loom somwhere so i dont have to rewire when i change head units.
    Cheers in advance.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Aug 2011
    Speaker Level only, you can turn the speaker level down through VCDS which gives a nicer signal to the amp. RCD510 and RNS are the same in that regard so no worries
    May 2012
    Quote Originally Posted by readerr0r View Post
    Will this only affect the amp or all speakers? Where do I tap in?
    MY12.5 Polo 6R GTI
    Aug 2011
    My bad, thought you were adding speakers too.
    Turning down the speaker level will affect all speakers that are connected yes, it's not really necessary if you're just doing the sub though. Best bet would be to tap into the harness at the back of the head unit (the rear speaker lines). I don't think there is any plug and play style harnesses that'll split it for you.
    May 2012
    im going to change the spekers as well but not going to amp them (yet). i feel ATM the sound is a little tinny, distorts real easy and could use some better splits. its completly lacking bass. i just got out of a liberty gt-b with 14 speakers so anything going to sound a little ordinary i guess. i have the wiring plans so should be able to find the rear lines.
    MY12.5 Polo 6R GTI
    Aug 2011
    Quote Originally Posted by lunchboxGTI View Post
    I'm actually quite impressed with the accuracy of the speakers in the Polo (when paired with an RNS510 with its secret loudness setting off), sure they can't really do bass (unless it's just the bass note by itself) but they have a nice flat response that lets you hear the subtle background effects added to songs. A nice sub would be your best bet.
    I went from a HK equipped BMW E46 myself
    Feb 2008
    New Zealand
    Pm user glidn he does all this sorta **** all the time
    Sent from my GT-I9300T using Tapatalk 2
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Jul 2012
    If you don't mind me asking.. Could I get a copy of the wiring plan? If not, what colour is the accessory wire?
    Jul 2012
    Correction to that.. What colour would the accessory wire be for the rcd510?
