Results 11 to 20 of 21
Thread: What difference, if any, should I see in my MFD having installed an RNS510?
    Jan 2012
    Canberra
    Thanks for the response, appreciated. I had not done the first bit... BUT:
    My equivalent screen above under 19 - CAN Gateway, Long Coding, (as well as mate's who has an R) looks very different to the above screen (screen shot here: https://skitch.com/javab0y/8dine/img-0219.jpg)
    Click for large view - Uploaded with Skitch
    Any ideas?
    I did get the needle dance and the emergency contact button number change happening though!
    EDIT: Found it, I didn't have to do the above Step 1. Just had to go into 19 and then go Into "Installation List" and then Select 37 Navigation and that's it!
    So happy.
    BIIIIGGG Thanks again Erkin.
    Golf GTI ED 35: DSG, Candy White, Tinting, RNS510 retrofit
    Jan 2011
    Perth, Western Australia
    Unfortunately still no luck at my end.
    I spoke to my dealer, who basically said there was nothing further they could do.
    I've made enquiries with Quattro Motors here in Perth, however they have advised that I will need to have the coding before I head in. Not 100% on the coding side of things.
    That said, glad you managed to get things at your end up and running!
    MY11 Golf GTI MKVI | Candy White | 5 door | DSG | 18" Detroits | Electric Vienna Leather | MY11 Bluetooth | MDI
    Jan 2012
    Canberra
    Quote Originally Posted by Hhawker View Post
    Unfortunately still no luck at my end. That said, glad you managed to get things at your end up and running!
    Sorry to hear & thanks! Very happy. Can imagine how annoyed you must be - bugged me too, for the few hours it was not going.
    I suggest finding a VAG unit and trying this: Just had to go into 19 and then go Into "Installation List" and then Select 37 Navigation - that's what did it for me.
    Mindarie, Perth (WA)
    Hawker.....have you accessed the navigation gateway via VCDS cable yet? Do you have access to a VCDS (RossTech). Cable?
    Jan 2012
    Canberra
    On a related note... I want to sell my RCD that was removed, anyone tell me where to find the security PIN code? I assume I need this? It is not in the stuff that the dealership gave me (that I can see anyway). Will the dealer give it to me if I called and asked, I suspect that they will want money - but I will try tomorrow.
    EDIT: Called up dealer, Lennock in Canberra and they said they have to put the RCD back in, plug in cable to get the code, and then put back the RNS? ...and of course charge me for it. Is that for real? Surely there is an easier way.
    Jul 2010
    Robina Gold Coast
    Take your vin number and the radio to the dealer thats all thay need .
    Jan 2012
    Canberra
    Quote Originally Posted by ian View Post
    That's what I have been told too by others, but that's what the dealer said over the phone. I will have to rock up there and try my luck?
    I doubt very much that it will be that easy: I know the Canberra dealers are a lot more "special" compared to other states for some reason...
    Jan 2011
    FJ Steve, I haven't yet had the opportunity to have a fiddle using VCDS. Unfortunately I don't know anyone with a cable, and haven't yet taken the plunge to get one for myself.
    I have contacted a local VW mechanic however, and they've said they can have a look at the coding as long as I'm aware of what needs to be changed to get things working. That's where it's a little tricky.
    As far as the security code is concerned. I was at my dealer this week while they had another go with the coding and replaced a part. I asked for the old RCD510 code and the Service Manager just jumped on his computer and had the code for me in about 30 seconds. Totally painless and free!
    Fingers crossed your dealer gets their act together and organises that code for you.
    Oct 2011
    melbourne
    Hi guys Anyone in Melbourne by any change can help me with coding the VCDS
    i just installed RNS 510 version F to my car and hoping someone with VCDS could lent me a hand ( willing to go around Melbourne area ) as my 1st service still couple more months
    or can anyone refer me to someone who might able to help me ( around Melbourne ) eager to have my compass working
    cheers,
    Wil
    Golf 118 Comfortline TSi + Sport Pack + MDI ( Factory fitted ) + Bluetooth ( Factory Fitted )
    MOD. RNS - 510 Version F
    Apr 2010
    Whereabouts are you atm? I'm in the CBD (finish work at 5pm) and might be able to spare a couple of minutes. Got an appointment later so can't be too long.
