Results 1 to 7 of 7
Thread: What can i retrofit
    Jan 2018
    What can i retrofit
    Hi guys,
    I have a golf mk7 2013 highline with a discovery pro (the older smaller one). The pixels on the screen however are dying wondering if there's a unit with bigger screen i can retrofit and work with it if not else i can find which would be an upgrade to fit. I have the stock rear camera etc too so hoping to keep that functionality.
    You can retrofit the new 9.2 inch infotainment and Discover Pro MIB 2.5, also the Active Info Display instrument cluster if you want to really update....
    Or you can do MIB2 with 6.8 or 8 inch screen.
    Jun 2013
    Qld
    Hi Kamold.
    Can you tell me if i can swipe a non DAB+ discover media model 5C0035680F with an unit with DAB+. Ex: 5C0035680B or whatever is available in Australia.
    My dealer is saying the car computer will not let you do it?
    Thanks.
    What car is it going into?
    Jun 2013
    Qld
    Amarok V6 3.0l
    Sent from my SM-G965F using Tapatalk
    They are right in that you can't straight swap it.
    Once you install a new radio it will immediately lock it with component protection.
    A dealer can unlock it, but all feature enable codes for Bluetooth, navigation, app connect etc will need to be restored.
    Again it can be done with the dealer tools, just depends if they are willing to do it for you.
    You will also need to install a dab antenna or a splitter from your FM antenna.
    Jun 2013
    Qld
    Yes it's what I believed. Dealer can do it.
    No difference that replacing faulty unit.
    They are telling me its cannot be retrofitted.
    Thanks for your answer.
