Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 185
Thread: VW MY11 Bluetooth - VW 9ZB
  1. #151
    IN2VWS Guest
    Quote Originally Posted by YellowLemon View Post
    Hi! I'm a new member in Melbourne, just got a new MY2011 Polo TDI! Yay!
    I want bluetooth - is there someone in Melbourne willing to help with CAN programming please?
    First - Which module should I buy
    POLAND Ebay person - 7P6035730 - ? 9W7
    SPAIN Ebay person - 5K0035730 - ? 9WZ
    Thanks!
    Someone correct me if I am wrong, but isn't the part number for the 9WZ, 3c8035730a?
    When I plug my vagcom, that is the part number that comes up in my van.
  2. #152
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by IN2VWS View Post
    Yes you are right -sorry. The SPAIN Ebay person messaged me and said that the 5K0 035 730 is a brand new module, even newer than the 7P6035730 C (9w7). He said either is fine for me (VW Polo 2011).
    _____________
    Should I stick with ordering the 7P6 035 730 C because it seems "proven" ??? If it doesn't work with the RCD310 I guess I'll be forced to upgrade to the RNS510
  3. #153
    Mar 2011
    Gold Coast QLD
    This seller from Portugal has the 7P6 035 730 C unit for cheaper than the Spain and Poland shops. Costs EUR 155 + 25:
    Bluetooth VW RNS 510 9W7 UHV/RSAP AD2P / 7P6035730C /D bei eBay.de: Einbau-Navigationssysteme (endet 31.03.11 01:05:28 MESZ)
    It doesn't come with cable or micro, but you can order that separate from Poland for EUR 40+30 and it still works out cheaper:
    BT KABELSATZ OEM
    Just a suggestion
  4. #154
    Feb 2010
    Quote Originally Posted by Pepe View Post
    You're in Sydney... let me know if you need a hand with installation.
    i now have my BT from the spanish guy... all i need to do is chop my existing mic wire and join it to the similar black wire in the bluetooth harness?
  5. #155
    Quote Originally Posted by Sammy125TDi View Post
    Pretty much! Use the pinout diagram on Maverick's site (my-gti.com) and the existing plug as a guide as to what needs to go where. One thing to note: the cable to the mic in my R was a coax type cable, so you have to do a bit of careful cutting after you cut it and also make sure it's well shielded after you put it all back together.
  6. #156
    Feb 2010
    Volkswagen RNS 510 Microphone Connection for voice control | my-gti.com
    this one?... option 2?
  7. #157
    Mar 2011
    Gold Coast QLD
    Yes, it would be logical to connect the bluetooth kit "mic in" wires to the "mic out" pins of the rns510. So rns510 receives the mic input first (for voice control) and passes it to the bluetooth unit for .. bluetooth !
    See here for more details:
    http://www.vwclub.co.za/phpbb3/viewt...49326#p1149326
  8. #158
    Dec 2010
    Stereo or all speaker mono?
    Hi guys, just got my Spain 9w7 kit installed - it seems to be mono to all speakers, not stereo from my testing. Can anyone test and confirm? It's not obvious from normal listening - sounds awesome but I did some test tracks and confirmed.
  9. #159
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Enjayjay View Post
    Hi, I saw something online about re-wiring the harness for two channels: Bluetooth 9W7/9WZ pinouts?
    Although the fact you have mono coming out of both speakers indicates two channels are indeed being carried across.
    What BT phone are you using? Perhaps it doesn't support A2DP/stereo? My old Nokia would only use "standard" BT audio, and it was mono
  10. #160
    Dec 2010
    Thanks YL I have seen this before - the old harnesses didn't have wires for left channel so different issue. I have left speaker but it's all mono - same left and right. I have iPhone 4. Reason I suspect something is the dealer told me the new cars only have mono also - before I ordered it.
    Either way if we can confirm that it is stereo in factory cars, or that the iPhone only does mono, or that the Spain wiring harness is no good! If anyone can have a play and let me know it would be great. My kit was 5K0 035 730
    Cheers!
