Page 15 of 19 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 185
Thread: VW MY11 Bluetooth - VW 9ZB
  1. #141
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by ITguy View Post
    If there's already a mic there, why do you need to replace it?
    Can't one use the existing one?
    Thanks
    Yes... that's what we've been saying!
    If you already have a mic there, because you're purchased a car which has "voice control", such as the Golf R (or maybe it's cars delived with RNS-510...), then you don't need to replace the mic, or even run a 2nd mic, you can just use the existing mic! As per what Pepe suggested.
  2. #142
    Unhappy Having vagcom trouble!!
    Quote Originally Posted by nhand42 View Post
    That guide is heaps better than the instructions I worked from. Very comprehensive.
    I wouldn't worry about the coding too much. The VCDS tweaking is the least difficult bit of the installation.
    Hi Guys
    Bit the bullet and ordered the 9WZ kit from the spanish guy which arrived in only about a week! Today went over to VA garage so that Adam could put it in. I printed out the instruction guide that was kindly linked.
    But.... having trouble with the vagcom coding apparently. Adam says that he the car won't recognize the telephone part of the kit. He rang VW who said that the kit part number is not one for Golf. Something about it needing to be 1k9 rather than 1w9...
    Any suggestion will be greatly appreciated! Otherwise I guess I'll have to try to get the kit exchanged or get the 9W7 one instead. Sigh
    MY07 MKV GTI DSG CW 5dr Apr stg2 [gone]
    MY10 MKVI Golf R Reflex Silver DSG 5dr BLUEFIN MDI (dealer fitted). [gone]
    MY12 VW UP! baby blue 5dr
    Expecting MY14 Audi S3 SB White S-tronic
  3. #143
    Jan 2011
    Canberra ACT
    Quote Originally Posted by sameatworld View Post
    I have a 9W7 working with an RCD510 and the white Multi-Function Display. In case it helps, I've dumped some screenshots from VCDS.
    I don't think anything changes in 09 Central Electronics, but just in case.
    Enable the Telephone in 19 CAN Gateway.
    Enable the PTT button in 16 Steering Wheel.
    Long Coding Helper doesn't work in 56 Radio. Here's the raw code.
    Here's the 730C itself in 77 Telephone.
  4. #144
    Wow thank you so much!
    I'll give it a go and hopefully it will work. Otherwise may need to swap for 9W7!
    Will let you know
  5. #145
    9wz
    Just a quick update
    Unfortunately no luck with the coding. Adam could not put a long code into the telephone and enable the telephone bit to start of with! Apparently when he puts in the binary it just says that it can't be done.
    Maybe it's my car. Or the vagcom version? Or the unit...
    Not sure what to do now. Any suggestions?
    Thanks once again
  6. #146
    Jan 2010
    Pacific Pines, Qld
    Does anyone know if you should be able to connect more than one phone at a time to the 9W7 system.
    I installed the 9W7 in my polo last night and all is working great but I can only connect one phone at a time. Not a big problem just wondering if I should be able to connect more than 1.
    I got the 9W7 kit from the Spanish eBay seller.
    regards
    petho
  7. #147
    Quote Originally Posted by petho View Post
    regards
    petho
    You can pair a few, but it won't auto switch between them if you get a call on one that isn't the one that's hooked up at that moment... you have to switch manually.
  8. #148
    Mosman, NSW
    Just a quick update
    Thanks once again
    Hi mate...did you have any luck with this.... sounds like I'm in a similar situation to yours and was looking to get the 9WZ - still trying to understand the pro's and con's - sounds like you may have hit a big con. Interested to hear what you did to resolve.
    My last post was asking questions in regards to this:
    http://www.vwwatercooled.org.au/f78/...-31461-29.html
  9. #149
    Mar 2011
    Gold Coast QLD
    Hi! I'm a new member in Melbourne, just got a new MY2011 Polo TDI! Yay!
    I want bluetooth - is there someone in Melbourne willing to help with CAN programming please?
    First - Which module should I buy
    POLAND Ebay person - 7P6035730 - ? 9W7
    SPAIN Ebay person - 5K0035730 - ? 9WZ
    Thanks!
  10. #150
    Mosman, NSW
    That's the million $$$$ question. There are a few posts with comments/info still not sure which way to go I think 9W7.
