Originally Posted by
faisan
Does your AVC9000-1 function properly with the on/off and also MDF integration?
It works the same as the RCD500 and turns on/off with the ignition but you can't run it with the key out of the ignition though. There is no display of info in the MFD. I want to get a small under seat sub woofer and was looking at a Focal (76x348x242 mm) BUS 20 8 inch. I think I could get one for about $400. Most people say that a sub woofer makes a good difference.
Tx
Craig
Ncle NSW
Candy White 07/10 R36 VW Wagon. sunroof, tint, RNS510.
