Sorry Polar, can't help...
Mine doesn't connect to bluetooth except when I specifically re-pair it with the phone. So I don't have your problem... Wish I did...
BUT - on the few cases when it has appeared to pair with the phone that was programmed last time (maybe after 1 hour of being shut down), I have seen nothing like you are saying (ie bluetooth appears to connect in the background as you would think it should). So I am a little confused.
That brings up another question:
What section of the AVC9000 system do you use to set up the bluetooth?
Stupid question, but there seem to be TWO bits of bluetooth connection software.
One is under "SRC" where you select the BLUE source and go through the motions, this allows dialling via the dial pad, as well as call and answer functions.
The other is the rather stylised-looking bluetooth logo that is in the underlying menus for the NAV. ie you select NAV and then EXIT from whatever NAV programme you are using after waiting for it to load, then you can see the bluetooth logo as one of the big icons on the screen (far right without selecting right arrow IIRC).
Does anyone know which is the go for this?
Maybe someone who has had reasonable success with the set-up and use of AVC9000 bluetooth can jot down a step-by-step for how to make it all happy??
cheers,
..Neil
