Page 33 of 53 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 521
Thread: Volkswagen Golf/Jetta SAT NAV
  1. #321
    Mindarie, Perth (WA)
    I scored the Fakra leads.....only way to fix your radio issues.
    As for the B'tooth, check the settings on your phone. You should be able to have the phone pair with the AVC as soon as the phone comes withing distance (3 - 5 meters) of the unit.
  2. #322
    Jun 2008
    Wollongong, Oz
    I agree with Steve. You need an adapter that allows both antenna leads to be used.
    As for Bluetooth. I have no trouble with the pairing staying between reboots. Might be more of a phone problem, than the AVIC.
    Mind you, the AVIC is pretty crappy bluetooth wise. Sure it connetcs and works, but with the mic being on the lefthand side of the unit, and it appears to be voice activated, I find people on the other end of the line have difficulty in hearing you. For some, they will find that OK. I just have greater expectations. But Hey!. The unit overall, is value for money.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
  3. #323
    Apr 2008
    Baulkham Hills
    Does someone have a direct link to a supplier of the Fakra leads?
    My radio is poor between towns (actually no worse than my other car, but was perfect before).
    As stated above, bluetooth not perfect but liveable.
    My next mission is to fiddle with the flash card to see what else the unit can do.
    MY08 Passat Sedan
    Metallic Silver
    125KW TDI, Sat/Nav
  4. #324
    Jun 2008
    Wollongong, Oz
    If you read back through this thread, you will see a couple of alternative adapters that would work.
    One is from http://www.advancedice.com.au/produc...?number=970769
    Another is from one of the well known radio accessory suppliers. (Cant recall name offhand)
  5. #325
    Jun 2008
    Cronulla, NSW
    My 2.2cents for the Bluetooth solution is to drop $100 (or less now) on Ebay and grab one of the Blueant Supertooth unit (get the black ones, not the silver or white ones, they seem to suck) because they are by far and away the best bluetooth units for duplex voice quality.
    sure, it is an extra thing rather than having the AVC do it all, but tbh the bluetooth on the AVC sucks the left one badly and if you are going to speak to someone you may as well do it properly. Nothing worse than having to repeat yourself 5 times cause the mic won't pick up what you're saying, just gets annoying.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
  6. #326
    Nov 2008
    Canning Vale, WA
    I emailed Auspack and it seems they still sell the AVC9000
    Is there anyone in Perth who can let me look at their AVC9000 in action? I live in Winthrop (south of river) but work in the CBD.
  7. #327
    I am home next week...and will have my camera working (finally)...and I have the AVC set up ......
    I'll PM you with mobile number details etc.
    I am NOR...Mindarie
  8. #328
    Blackburn South, Victoria
    AVC-9001 for MkIV
    Just got a reply from rob, he has the AVC-9001 for the MkIV Golf/Bora. $950 including reversing camera & maps. Now to convince the minister of war & finance
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
  9. #329
    Nov 2008
    Canning Vale, WA
    I just noticed that the AVC 9000 only has one AV input.
    I have a DTV twin tuner that I would like to connect. However, it seems you cant connect both this and the reverse camera at the same time.
    Does anyone know if you could plug in one of those RCA Y splitters so you could plug 2 x AV inputs into the single AV input connection? The reverse camera would only come on when you are reversing and during the other times, you would use the DTV tuner.
    Thoughts?
  10. #330
    Quote Originally Posted by faisan View Post
    Thoughts?
    sounds feasible.
