Page 28 of 53 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 521
Thread: Volkswagen Golf/Jetta SAT NAV
  1. #271
    Sep 2008
    Oh ... have a lot of questions to answer.
    Can you please help me with these:
    1. Do I need to disconnect the battery? Does it affect on anything else in the car?
    2. As I understand I don't need to connect P-CONT if I don't have the external amp?
    3. I have 2 pack of screws. What are they for? I think I don't need them, right?
    Thanks
    MY06 Passat Sedan, 2.0TFSI, Silver Blue, Leather & memory, Sunroof, Bi-Xenon
  2. #272
    Jun 2008
    Wollongong, Oz
    Quote Originally Posted by dkan View Post
    Thanks
    1. Although you may not make a mistake, it is prudent to disconnet the battery when working on electricals.
    2. I do not understand P-CONT. Basically you need to disconnect the CANBUS plug from the old radio, and connect it to the new adapter.
    3. I never used mine.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
  3. #273
    Sep 2008
    Thank you allypally.
  4. #274
    Jun 2008
    Henley Brook WA 6055
    P-Cont = Power continous and is for running an external amp. No amp no use
  5. #275
    avc 9000
    Hi guys,
    i am currently having the AVC9000 installed into my GTI and the auto electrician has called me with 2 problems.
    1. there does not appear to be any sat nav software installed (Route ot Tomtom). Is this on an SD card or does it come pre-installed?
    2. The steering wheel buttons dont work even though he has connected it. has he connected the right way?
    Any help would really be appreciated
  6. #276
    Apr 2006
    Hobart,Tas
    The SD card should already be in its slot up the top behind the rubber flap thingy.
    Steering controls are connected via the small black wire and plug.
    Good luck withy it mate,
    Andrew
  7. #277
    cheers Andrew.
    do you know what the black plug should be pluged into for steering controls?
  8. #278
    Sep 2008
    AFAIK,
    The black plug (the one which comes out from the small black box) should be connected to the jack comming from the unit as one of the wires according to the installation instruction.
  9. #279
    Jun 2008
    Wollongong, Oz
    The steering wheel controls ONLY work with the ignition on.
  10. #280
    Jun 2008
    Wollongong, Oz
    dkan is correct. It seems strange, but the black lead (looks like a stereo plug) plugs into the REM lead from the radio. Apparently it pumps power into another section of the Units motherboard. Why they didnt just wire it in permanently is probably to cater for other makes of car.
