Page 41 of 53 FirstFirst ... 31394041424351 ... LastLast
Results 401 to 410 of 521
Thread: Volkswagen Golf/Jetta SAT NAV
  1. #401
    Nov 2008
    Canning Vale, WA
    I also installed my digital TV Tuner today. Its an old unit that I removed from my old car. It does a good job and has dual diversity antennas to help improve reception.
    Here is a picture showing the Hopman Cup live on ABC
    The tuner box is installed under the front passenger seat. I have one antenna on the front windscreen and one on the rear under the headlining so its hidden from view. I am trying to improve reception still so if anyone has experience with in car TV, speak up
  2. #402
    QLD
    Quote Originally Posted by macdoc View Post
    Can you advise the brand and/or part number of that powered Y adaptor.
    Thanks in advance.
    PS. iGO is the way to go, just got to get it a bit more 'stable'...
    Macdoc
    Found the empty pack...
    It is a Connects2 CT27AA25 - "Aerial Adapter 2 Fakra - DIN Active Aerial".
    description
    CT27AA25 Aerial Adapter
    All cars with 2 OEM AM/FM Fakra Aerials
    2 x Fakra to 1 x DIN Aerial
    with amplified remote feed
    Attached Thumbnails Attached Thumbnails Volkswagen Golf/Jetta SAT NAV-ct27aa25-jpg
    Octavia vRS TDi DSG MY10 - RD Technik tuned
    Polo 9N3 1.9TDi
  3. #403
    Nov 2008
    Canning Vale, WA
    Quote Originally Posted by harlie View Post
    description
    How much was this adapter?
  4. #404
    Jul 2005
    has anyone downloaded updated maps yet?
    I run the tomtom maps and wondering where i would get them from and easiest way to get them on the unit.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
  5. #405
    Nov 2008
    Canning Vale, WA
    Just an update...
    Today I installed a Parrot 3200LS bluetooth carkit in conjunction with my AVC9000. I bought a Parrot adaptor lead so no splicing was required. All I needed to do extra was to connect the accessory wire seperately as the stock wiring loom doesnt have this. I ended up tapping into the AVC harness's accessory wire.
    The Parrot works perfectly with the AVC. When you make a call or a call comes in, it mutes the stereo and the conversation goes through you car speakers. When you hang up, the music starts again.
    I mounted the Parrot screen to the right of the AVC just under the air con vents. This was the best location as I can easily view the screen while driving and access the buttons and volume knob.
    I tried the AVC's built in bluetooth for a while but decided to put the Parrot in as it performs better. The AVC surprisingly had decent sound quality (no real complaints from my callers) but the main bug for me was that it was slow to switch between music to the bluetooth source.
    If anyone is interested, I can post a picture of my Parrot display
    2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
  6. #406
    Dec 2008
    Lilydale, Victoria
    Quote Originally Posted by faisan View Post
    I've just purchased one of these aerial patch leads from Connects2, it cost about $80.
    Macdoc.
  7. #407
    Sep 2006
    Macdoc.
    From Advanced ICE in Brisbane, $30 + $10 postage. They are Connects 2 importer...
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
  8. #408
    Nov 2008
    Canning Vale, WA
    Heres a pic of my Parrot 3200LS screen fitted next to my AVC9000.
  9. #409
    Sep 2006
    Well mine has gone back to Rob at Auspack... It was repeatedly failing to find the GPS device. This is not a signal strength (ie aerial position) issue, as when it decides to work (about 1 day in 5) there are lots of satelites with lots of strong signal... So, after an involved discussion with Rob (who was very friendly and seemed to know the product thoroughly) he will get it checked out by techs and either returned or replaced. So, here's hoping....
    ..Neil
    Audi Q5 2.0 TDI
  10. #410
    Mindarie, Perth (WA)
    Any MKV R32 owners out there who have the AVC9000?
    Did you install the reversing camera? If so, where did you locate it?
    I am about to get my 3rd camera, and I am wondering if the vibration/resonance from the install location (between and above the exhaust pipes) might be upsetting the camera.
    I get a "reversed" image (what's on the left shows on the right, etc).
    Yes, I have gone through the software settings at the head unit, and that makes no difference at all.
    Rob (Auspack) is at a loss to explain.....and I would really like this sorted out.
    So...any feedback from the .:32 owners?
