Guys anyone using iGo maps....whats your thoughts feedback.
I currently use Garmin GPS units and love it, I am not a fan of tomtom menu's and i just dont like route 66.
One of the sellers offers iGo maps...they look ok but i have had no experience with them, hence this post
MY08 Jetta 2.0 Turbo FSI - OJE774
Graphite Blue / Beige Leather / Sunroof / 18' Fox Rims / Tint / iPod Adapter / Bluetooth /
There are more than enough positive comments about iGO in this thread to recommend it.
You will need 2 parts. Neither of them are powered by the way.
Aerpro AP339 - this coverts a single male DIN antenna plug into 2 x female DIN sockets so you can plug in 2 x DIN antennas.
Stinger BKBAA22 - this converts the Fakra antenna connector into a standard DIN type so you can plug it into the Aerpro adapter as above. This is the same as the adapter that comes with the AVC9000.
GTIMK5 kindly posted a picture of these parts in another thread. Here is that pic again.
I prefer iGo to TomTom. I was/am a big TomTom fan also.
The main thing that iGo does better is that its easier to type addresses into. As you start typing the each letter, the system grey's out the next letter that cant follow the fist letter you have typed. This means you get fewer input errors. TomTom doesnt do this and its easier to make mistakes.
Apart from that, they both do the same sort of job.
Thanks Paul for that. Forgot to mention I have a 06 Polo GTi which has the lamest radio for expansion so RCA outs are very much a drawcard to this unit for me.
In regards to the antenna situation with the adapters, does the TV antenna also integrate into it as well? Most have said that the TV reception is poor and I am wondering whether this can be improved or not?
If you measure your aerial socket on the AVC9000 you'll notice that it has 12V coming out. I'm thinking that you don't need the active cables that are available because there is an antenna amp located somewhere else in the car - you just need a head unit that can supply power to it.
As I stated in earlier post – I have done it with ONE part - Autobarn now have a single part it is Double fakra to single DIN Antenna with a powered signal booster in line - especially for the new VW range.
Sorry should have taken a pic and to be honest I was so relieved to have it sorted all packaging has been thrown so I don’t have a part number... Autobarn at Capalaba (07) 3245 7556 had to make a call to their supplier as it’s not in the catalogue yet – Manger (Craig) sorted it for me. Brand is Connects2 but I can't see it on their website - it's new.
Octavia vRS TDi DSG MY10 - RD Technik tuned
Polo 9N3 1.9TDi
I decided to do some investigating to see where the antenna was in my Jetta. Here is a picture of it.
You can see the white connector on the left and brown on the right. They seem to be going into the same circuit board which also has an earth wire coming out of it which indicates its powered some how.
There is no roof top antenna with the Jetta so Im not sure why they bothered with a diversity antenna set up when both antennas are in the same spot
Anyway, the Y adaptors I bought solved my FM issues but AM doesnt seem to work. I don't listen to AM so its not a problem for me.
