Page 35 of 53 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 521
Thread: Volkswagen Golf/Jetta SAT NAV
  1. #341
    Jun 2008
    Wollongong, Oz
    Quote Originally Posted by runlad View Post
    Hi, new to the forum, recently got a 06 golf gti, and after reading this forum, Stumbled upon this topic about the AVC-9000. Are there any of them left, coz it sounds like a pretty awsome deal? I know it has been asked 10000 times probably, but does anybody know if they are still able to be purchased and where at.
    Thanks.
    You need to do a "little" self help. Read the first post in this thread. You will see a link to the original supplier. Then you need to contact him and see if he is still in this business.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
  2. #342
    Nov 2008
    Canning Vale, WA
    I have just found a UK website that has some good actual pictures of this device and the connection the in back.
    It definitely shows a lot more connections than the stupid manual
    http://www.esg1.co.uk/2-din-gpsdvd/d...gon-p-250.html
  3. #343
    Nov 2008
    Canning Vale, WA
    Ok I have decided to buy one of these.
    Rob from AVC has advised that you get a choice of IGO8 or TomTom. Which should I choose? I have used TomTom for years and find it quite intuitive and easy. Whats IGO like?
  4. #344
    Mindarie, Perth (WA)
    a choice?
    When we purchased from Rob...you got Route66, Tomtom, IGO8 all on the one card. Better confirm with him again...maybe he's "setting" it up for you.
    I prefer IGO8....and when we get the street number problem sorted out in the NEW IGO8, then I will swap over to that.
    Maps can be sorted out quite easily. Plenty of available "resources" (if you know what I mean).
    But..if he's giving you a choice....IGO is the way to go.
  5. #345
    Apr 2008
    Baulkham Hills
    I only received Route66 and TomTom on my unit. I use TomTom at the moment.
    Does anyone know how big the IG08 folder is on the memory card? I would like to get a copy an put on mine, as it's meant to be the best?
    MY08 Passat Sedan
    Metallic Silver
    125KW TDI, Sat/Nav
  6. #346
    The version on the card is about 350MB. I have a new version of IGO8 and that is 548MB
  7. #347
    Sep 2008
    I also have got only Route66 and TomTom. It would be interesting for me to look what is the IGO about because I have no idea what is it What does it do better than TomTom? Always used before TomTom. Have tried routte66 and it is not good. Currently I'm using TomTom.
    Does anyone use bluetooth? I have found interesting effect on mine. Sometimes it keeps the volume level for bluetooth different from volume level on radio. Has happend several time but I still can't figure out what are the conditions.
    And also have found another bug: if the USB in use and a call accepted by bluetooth, then after that the unit doesn't return back to the USB mode. I need to unplug USB and plug it again.
    MY06 Passat Sedan, 2.0TFSI, Silver Blue, Leather & memory, Sunroof, Bi-Xenon
  8. #348
    Nov 2008
    Canning Vale, WA
    dkan - how do you find the sound quality with bluetooth?
  9. #349
    Jun 2008
    Wollongong, Oz
    Bluetooth sucks, so don't rely on it.
    Wish I had IGO.
  10. #350
    Nov 2008
    Canning Vale, WA
    Quote Originally Posted by allypally View Post
    Wish I had IGO.
    I don't know if I should get a Parrot 3200 car kit ready to install at the same time as when I put in the AVC9000. I would like to test the AVC9000 first but if its crap for bluetooth, I will need to pull apart the dash again to put in the Parrot.
