Page 27 of 53 FirstFirst ... 17252627282937 ... LastLast
Results 261 to 270 of 521
Thread: Volkswagen Golf/Jetta SAT NAV
  1. #261
    Closet Diesel Owners Club President.
    Fo shizzle.
    My avc9000 has grown on me so much. Once you fit a sub woofer to the system it just sounds fantastic. CAuse you can turn the bass down on the front speakers and let them just do the mid and treble.
    Its such good value for the money.
  2. #262
    Mindarie, Perth (WA)
    ****HELP****
    And I don't need any suggestions about what I should have bought...thankyou.
    The AVC is now installed...thanks zz2 & mrX (& Tim).
    Problem is with the GPS (Navi) screen. It seems that the "touch" menu options on the screen are all arse about face. The icons appear in the lower half of the screen, but the touch function for each icon is diagonally opposed to where it should be. Also, the Navi screen now has moved some millimeters to the left, making it even harder to select any options.
    I had taken a back up of the SD card, and since this issue, have reformatted the card and reloaded the OEM files. No good.
    I have done a full reset (little pin in reset hole...top right hand corner). No good.
    Radio works fine. Clock works fine. DVD works fine. Reverse camera not working yet (as the cap/diode blew up during install....awaiting new components from Radio Spares). USB connection works. BT works. Farken Navi screen is ar.e about face. Therefore no GPS software/maps etc.
    Suggestions?
  3. #263
    Jun 2008
    Wollongong, Oz
    I have never heard of a "mirror" image on a Navi screen.
    All I could suggest is that you re synch the touch screen.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
  4. #264
    Also....a recalibration of the touch screen has been done. No good.
  5. #265
    Apr 2008
    Baulkham Hills
    Does the Route 66 and Tom Tom have the same problem? (ie screen calibration and tough button wrong?)
    MY08 Passat Sedan
    Metallic Silver
    125KW TDI, Sat/Nav
  6. #266
    Jul 2005
    getting mine installed next monday.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
  7. #267
    Jun 2008
    Wollongong, Oz
    In the AVC9000 setup screen (tools) there is a "mirror" switch. You might try that. However, I think that relates to the Reverse Camera image only. Just a thought.
  8. #268
    Jun 2008
    Wollongong, Oz
    Quote Originally Posted by irish_Tim View Post
    From the source menu go into setup, turn RDS to off then go back to the radio and you will see ST, press it to change to stereo Can go back into setup on source screen and turn back on rds if you wish
    As explained to me by Polarbear66
    Thanks for that. It worked.
  9. #269
    Sep 2008
    I've got my AVC-9000 today from Auspack.
    Now I need to organize it to be installed. Can you recommend me any place in Melbourne where I can install it? Or may be it doesn't worth it and it's easy to install it by myself? Or I have to have it installed professionally to keep warranty on this unit?
    How much did you pay for professional installation?
    Thanks
    MY06 Passat Sedan, 2.0TFSI, Silver Blue, Leather & memory, Sunroof, Bi-Xenon
  10. #270
    Jun 2008
    Wollongong, Oz
    You should be able to easily install the headunit yourself.
    The rear cam involves some panel removal and drilling as well as connecting to the reverse light wiring (white at the bulb connection for a GolfV).
