Results 1 to 10 of 46
Thread: Video in Motion
    Feb 2009
    Torquay
    I have also had success with the Berto VIM file. (the myCDiso did not work).
    2010 Transporter
    Burnt disc at 24x using Imgburn (nero didn't work properly)
    Please note: when I inserted the disk it came up with CD error but it did not eject. Don't push the OK button and it will then restart and detect the CD and start the process.
    Melbourne, VIC
    Just used the Berto ISO image in my 2010 GTI and it worked flawlessly.
    Took ten minutes in total including burning the ISO. Only problem encountered was a 'clamp issue' when inserting the CD which involved changing the time format to 24-hour time. The CD wouldn't work with the keys in the ignition, but installed perfectly without.
    Thanks for the tip!
    2010 Mk6 GTI / CW / 3dr / DSG / 18" Detroits / RNS-510 w/VIM! / RVC / Bi-Xenons / MDI / Euro Plates / 9W7 / VCDS Micro-Can / APR Stage 1
    Apr 2010
    Will give this a go and report back, thanks.
    [+] Updated software, all works fine.
    Jan 2010
    City, NSW
    LEGEND!!
    Works on mine as well. Had the clamp issue and fixed it by changing the time setting and not having the keys in the ignition as 'ithinkimightbe' advised.
    Jul 2010
    Quote Originally Posted by l3lazin View Post
    LEGEND!!
    Clamp issue is actually ID10T fault code the unit throws up!
    Only appears if keys are in!
    With all RNS510 FW or SW installs, make sure there's no keys inserted!
    Just turn the unit on manually!
    MY11 Tiguan 147TSI (SOLD)
    Dec 2009
    VIC
    Fan-friggin-tastic! That mycd.iso works a gem in my GTI mk6 from Mar 10...! No key in ignition, do a reboot with < and > and * held, and wait for it to do its thing then presto!
    Apr 2011
    How did I not see this sooner, worked first go in an 08 R36. Followed same procedure as mycl above.
    Thank you!
    Jan 2010
    City, NSW
    Quote Originally Posted by aussietig View Post
    lol True, the procedure is duly noted for the future...
