Results 31 to 33 of 33
Thread: Very Specific Questions - RCD510 with Bluetooth Module on Mk6 GTI Golf
  1. #31
    Quote Originally Posted by mythik View Post
    I've tried an 7P6 035 730 E revision unit, it has the same problem with non A RCD510. The cure was RCD510 A rev.
    What version of RCD510 do you have running there? Can you paste the part number? Mega curious.
    OK. Just hooked up VCDS and dragged out all the info. So I've got an RCD510 "A" unit hooked up to a 7P6 035 730 "F" bluetooth unit.
    So it looks like the RCD510 "A" is probably the way to go.
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L1636560
    Coding: 00000440020016
    Shop #: WSC 07456 790 50316
    VCID: 234F91E922C3C3001C7
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2730
    Revision: 1B001001 Serial number: 00007662423196
    Coding: 0A00000000010110
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_UHVNA A01015
    ROD: EV_UHVNA_VW36.rod
    VCID: 356B5FB194574DB0C23
    Aug 2011
    Melbourne, Victoria
    snip.
    Thanks for this! This was what I suspected. With the "A" unit you could have gone for a K revision BT unit which has less strange issues with A2DP, Bluetooth pairing and general support for phone profiles.
  3. #33
    Sep 2012
    Oslo Norway
    I have a European 2010 GOLF MK6 with a RCD510 A revision. i bought the 9w7 rev K from spain... I have everything working (including voice control). But But but but :
    - Bluetooth audio is only working on left Speakers (front and back) and good quality
    - i can barely hear people talking to me on the speakers. They can hear me perfectly.. When engine turned off i can hear them a bit as well only fomr the left speaker...
    Volkswage locally dont want to help me out as they said it is not a genuine product.
    i played a lot with VCDS and found a "base phone volume" parameters i tried to change but no help.
    When the phone rings, it sounds like i can hear it like an half second then it seems to go in mute mode or a like an dthen i cant hear people talking...
    Ny idea to help me out?
