Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: VCDS Scan, butt load of problems, help?
    Apr 2010
    The car thinks you have a CD changer but can't find it, so something is not coded 100% correctly there. Go in the Long Coding section of either 56-Radio or 37-Navigation and carefully read through all the Bytes and look for one that says CD Changer installed (or something else to that effect). Untick it if ticked.
    Aug 2011
    vic
    fixed i forgot the old ipod cable emulated the cd changer.
    if only i could fix my bt problems
    Apr 2010
    Have you got the latest version of VCDS - those error codes aren't discernable.
    I can only otherwise suggest you run through a bluetooth retrofit guide and make sure you've completed each step correctly:
    http://www.carsystems.pl/media/instr...oth%20v1.4.pdf
    Aug 2011
    vic
    that link doesnt work, and yes i am
    Apr 2010
