Results 1 to 10 of 15
Thread: VCDS Scan, butt load of problems, help?
    Aug 2011
    vic
    Having some malfunctions come up, could anyone help me diagnose?
    I have been to VW and am getting a new cam sensor, (my car barely starts), but the other stuff??
    Code:
    Chassis Type: 1K0
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 03G 906 018 FC    HW: 03G 906 018 FC
       Component: R4 2.0l PPD1.2 G    1879
       Revision: --H52---    Serial number: VWX7Z0H23NV8RC
       Coding: 0000078
       Shop #: WSC 00046 412 00000
       VCID: 6BD1C39F3315
    2 Faults Found:
    012295 - Camshaft Position Sensor (G40): No Signal
                   P3007 - 006 - Short to Plus - Intermittent
    000833 - Camshaft Position Sensor (G40): Implausible Signal
                   P0341 - 006 - Short to Plus - Intermittent
    Readiness: N/A
    Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
       Part No SW: 02E 300 050 C    HW: 02E 927 770 AE
       Component: GSG DSG         082 1402
       Revision: 09908020    Serial number: 00000803150152
       Coding: 0000020
       Shop #: WSC 04940 001 00001
       VCID: 122FBE7B74FF
    No fault code found.
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0023170
       VCID: 73E1DBFF6B25
    Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 6DD5CD870D01
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 00000008259901
       Coding: E5898F2700041500471400001400000000087F075C000100000000000000
       VCID: 71EDD1F71139
       Part No: 1K2 955 119 E
       Component: Wischer 130508 020  0501
       Coding: 00049109
       Shop #: WSC 00046
       Part No: 1K0 955 559 AF
       Component: RLS     090508 046  0204
       Coding: 00208933
       Shop #: WSC 00046
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
       Component: 1P AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1RW03Q
       Coding: 0012624
       VCID: 3D753DC71DE1
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           752 0101
       Coding: 0012122
       VCID: 78FBECD37243
       Part No: XXXXXXXXXXX
       Component: E0221           002 0010
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
       Component: KOMBIINSTRUMENT VDD 2216
       Revision: V0002000    Serial number: VWX7Z0H23NV8RC
       Coding: 0003103
       Shop #: WSC 30067 959 86331
       VCID: 2C530083F69B
    Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K083018194
       Coding: ED807F064006120003
       VCID: 306B14F3DAB3
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO            VDD 2216
       Shop #: WSC 30079 959 15689
       VCID: 2C530083F69B
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669863893
       Coding: 010000
       VCID: 285BFC93E263
    1 Fault Found:
    03138 - Input AUX IN
                009 - Open or Short to Ground
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
       Component: RNS-MID       H50 2760
       Revision: AB001001    Serial number: VWZ6Z7Z0000000
       Coding: 0E0004000400002200
       ASAM Dataset: ------------------------- ------
       VCID: 2E570A8BC087
    2 Faults Found:
    00857 - CD Changer Unit (R41)
                004 - No Signal/Communication
    01042 - Control Module; Not Coded
                000 -  -
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
       Component: Tuer-SG         006 1210
       Coding: 0000692
       VCID: 387B2CD332C3
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       VCID: 366722EB38D7
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
       Component:    KSG PQ35 G2  020 0204
       Revision: 00020000    Serial number: 00000000000000
       Coding: 999002005103087F2D04840560085F0380FC00
       VCID: 83010B3FBB85
       Component:   Sounder n.mounted
       Component:       NGS n.mounted
       Component:      IRUE n.mounted
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
       Coding: 0000692
       VCID: 397D29D709C9
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       VCID: 2E570A8BC087
    2 Faults Found:
                000 -  -
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
       Component: Tuer-SG         006 1301
       Coding: 0000144
       Shop #: WSC 00046 412 1012544
       VCID: 387B2CD332C3
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
       Coding: 0000144
       VCID: 397D29D709C9
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660093958
       Coding: 0A00000000010100
       ASAM Dataset: EV_UHVNA A01015
       ROD: N/A
       VCID: 356525E725D1
    No ASAM data for: "EV_UHVNA" (VW35)
    3 Faults Found:
    9455633 - ROD - Unknown Error Code
    9458195 - ROD - Unknown Error Code
    13636352 - ROD - Unknown Error Code
    End   ---------------------------------------------------------------------
    And please tell me if some of this should not be public :S
    v
    Dec 2009
    Kew, VIC
    Other than the cam sensor, all faults appear to be in the same module, so it's likely there's only fault one affecting more than one function.
    Do the faulted units still work?
    If they do, try clearing the faults and see if they come back — if they return, go over the connections at the back of the entertainment unit before you look anywhere else.
    And no, I don't see any really sensitive information in the scan (the engine number, perhaps, but it's not a lot of use to others.)
    Aug 2011
    vic
    Quote Originally Posted by Idle View Post
    What should i be looking at with the cables at the back?
    I replaced the RCD-310 with an RNS-510, installed the MDI and the bt module 9w7.
    (also my bluetooth streaming from bt does not work, it plays and stops on the iphone, but there is no audio)
    Feb 2008
    Perth WA
    vraptor when you took out the RCD-310, you would have picked up the "Input AUX IN - Open or Short to Ground" as the Aux in lead would have been disconnected.
    Like wise the "CD Changer Unit - No Signal/Communication" would have happened at the same time.
    As suggested above.. save the fault list to a text file, clear the codes and then run the car for a while.. then rescan to see if any of the faults come back.
    Mk 7.5 Golf R
    Aug 2011
    vic
    Quote Originally Posted by guthrie View Post
    The codes were cleared after everything was installed, so this is after they were cleared, they have come up again.
    Jun 2011
    N/A
    try setting a WSC for the RNS, and the Bluetooth, then clear codes and scan again
    Dec 2009
    Kew, VIC
    Mostly just the usual — cable or plug and socket damage, something not pushed fully home, dirty contacts etc.
    While you're at it, also check the fuse and any other junction points you can find.
    Since you fitted the RNS510 and other bits yourself, I assume you've been through the relevant VCDS settings and ensured that everything your specific installation needs is enabled?
    The bluetooth problem I've no idea about — never even looked at one (well, did try it on the in-house network once, found how slow and problematic it was and forgot it) and despite that I've been building and fixing computers for more than forty years (and machinery & vehicles for much longer,) these in-car devices are becoming far too complex for my now-senile brain.
    However there's more information available on the 'net these days than we ever dreamed we'd see.
    Aug 2011
    vic
    yeah i had a forum member help me with the installation, he said everything was done correctly.
    I do not know what WSC is, and i also do not know which fuses to look at >.>
    Sounds like coding is wrong. If you don't have a CD changer or aux in disable them.
    You also need newer .rod files to recognise the bluetooth unit. Update to latest VCDS.
    And 'Control Module; Not Coded' is coding also.
    Aug 2011
    vic
    thanks karnold but I don't know why it's wrong. cd changer or aux is ticked for the mdi :0
    oh and why does it think my rns is a c version? it's a d.
