Its plausible in so far as the feature may be able to be locked out via coding...
But to function, it would need to be unlocked, plus the map data would require the TMC decryption key to be already installed.
Would be happy to take a look at any member's MkVII that has v7 map data to confirm this...anyone in Sydney?
Given the Mk7's use the SD card setup now it could be different.
Dumb question, but how do you know what version of maps are loaded?
On my Oct 13 build MY14 103kW Highline, I clicked on "system information" while in navigation mode and the following was displayed:
Device part number: 5G0035846A
Hardware: 040
Software: 0421
Navigation database: 5G0919866A 0022 ROW 2013
Are there some clues in these numbers as to which version of maps is loaded?
Hold setup down until you get Am & FM and system Version information
press that and it should give quite a few lines of info
Including
Hardware N40 or similar letters
Scroll down to
Software 4120 is latest normally
Map version info 7920 is the latest
We know the map version we've got because we installed it
On the RNS510 you could hold the SETUP button for 30 seconds and find it in a secret menu.
You can't use the same map disc or files that are used in the RNS-510 unit that is the subject of this thread.
As far as I'm aware, you need to get map updates through a VW dealer as they're officially released, and there will be a (likely significant) charge. VW have locked the new Discover navigation systems right down, and no-one's yet found a way to get around them.
And the same goes with the Touareg's RNS 850 navigation system as the MK7's have. SD card with updates and expensive activation code from dealers only.
Rip off when you consider a portable GPS (with life time map updates) is a third of the price of a single upgrade and the maps are still 12 months plus out of date.
Flipper Dog
Now - T-Roc R, Audi Q5
