Page 4 of 15 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 142
Thread: V7 Maps for Australia
  1. #31
    Its plausible in so far as the feature may be able to be locked out via coding...
    But to function, it would need to be unlocked, plus the map data would require the TMC decryption key to be already installed.
    Would be happy to take a look at any member's MkVII that has v7 map data to confirm this...anyone in Sydney?
  2. #32
    Jan 2010
    Condell Park, NSW
    Is it usual for the new maps to be shipping in cars before the disks are on sale to the public?
    VW Tiguan 110TSI Life | Tungsten Silver
  3. #33
    Apr 2010
    Given the Mk7's use the SD card setup now it could be different.
  4. #34
    Apr 2010
    Adelaide, South Australia
    this would be great though but I don't think VW would enable it for the RNS....somehow I don't see it.
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
  5. #35
    Jun 2012
    Christchurch, New Zealand
    Dumb question, but how do you know what version of maps are loaded?
    On my Oct 13 build MY14 103kW Highline, I clicked on "system information" while in navigation mode and the following was displayed:
    Device part number: 5G0035846A
    Hardware: 040
    Software: 0421
    Navigation database: 5G0919866A 0022 ROW 2013
    Are there some clues in these numbers as to which version of maps is loaded?
  6. #36
    Pacific Paradise QLD
    Hold setup down until you get Am & FM and system Version information
    press that and it should give quite a few lines of info
    Including
    Hardware N40 or similar letters
    Scroll down to
    Software 4120 is latest normally
    Map version info 7920 is the latest
  7. #37
    Quote Originally Posted by scobb View Post
    Hardware: 040
    Software: 0421
    That sounds like the new nav system in the mk7. The info is totally different to the older rns.
    Sent from my HTC One using Tapatalk
  8. #38
    Apr 2010
    We know the map version we've got because we installed it
    On the RNS510 you could hold the SETUP button for 30 seconds and find it in a secret menu.
  9. #39
    Nov 2009
    You can't use the same map disc or files that are used in the RNS-510 unit that is the subject of this thread.
    As far as I'm aware, you need to get map updates through a VW dealer as they're officially released, and there will be a (likely significant) charge. VW have locked the new Discover navigation systems right down, and no-one's yet found a way to get around them.
  10. #40
    Jun 2007
    Sydney, Australia
    And the same goes with the Touareg's RNS 850 navigation system as the MK7's have. SD card with updates and expensive activation code from dealers only.
    Rip off when you consider a portable GPS (with life time map updates) is a third of the price of a single upgrade and the maps are still 12 months plus out of date.
    Flipper Dog
    Now - T-Roc R, Audi Q5
