Thanks guys. Downloading FJ Steves copy now and will give it a go.
For the record the one I have now is 677MB or 694,112KB or 710,770,688 bytes...
What firmware are you guys running?
I'm running 4020 in the Golf. 3810 in the Touareg.
Ok so the link to the ISO that FJ Steve provided is the exact same size 677 MB (710,770,688 bytes) but it has a different hash 6E344E4E1EC7923A34D54E90CB330B7C
My guess is this one will work. I will burn tomorrow and test and get back to you. Thanks for the help.
MY11 Superb Elegance Estate Amethyst Purple 3.6 V6 FSI 191kW DSG 4X4, Glamour Onyx Leather, Panoramic Roof, Sports Suspension, Multi Function Wheel, Sunset Glass, False Floor, Power Tailgate, KESSY, MDI, Bluetooth.
FJ Steves V6 iso fixed my issues...
So looks like there are 2 different V6 ISO's floating around, identical size, one is bad and gives the symptoms I explained (missing road names, missing textures when zoomed in etc..) one is good and looks identical to v5 (But i guess more up to date roads etc..)
The way to tell if you have good or bad is to check the hash of the ISO file you downloaded.. If you don't know how to calculate the MD5 sum of your iso, download HashTab for windows and then right click the file, properties and check the Hash tab, it will calculate the MD5...
Bad ISO
RNS510V6Maps.iso
MD5: 8A9F7D1F4F464CBCDCF7C9FC7337214E
Good ISO
RNS510V6Maps.iso
MD5: 6E344E4E1EC7923A34D54E90CB330B7C
Thanks to everyone for your help, especially FJ Steve for his ISO.
Ok mine seems its the bad one Have downloaded Jorges version which has the correct hashtab Have put the V5 disc in and gone back to that but sitting in the garage doesnt seem much different . So reinstalled the "GOOD" V6 version and its the same as mine was.
Will go for a drive in the morning and run V5 off the disc and do the same route with V6 on the HDD and see what happens.
