Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 295
Thread: V6 Australia Maps
  1. #161
    Pacific Paradise QLD
    Quote Originally Posted by dArK5HaD0w View Post
    hmmm.....mine won't save to the hdd.
    it keeps going through the download process.
    its been almost a week now, including a 3+3hr drive.
    car has had plenty of time to copy it, instead it gets to the end of the download process, then simply restarts the "download".
    when i attempt to remove the dvd, i get the message saying that the download is in process.
    if i do actually remove it, then it will ask me to insert the dvd navigation cd.
    going through the setup menu, it says i have 79xx maps.
    weird!!!
    maybe i should start the car with the navigation dvd not inside?!??!
    When u have that screen up press notify Mine took 17 mins to load the map.
    hop in car turn unit on WITHOUT key in ign put disc in, cross fingers and wait It will eject disc when finished
  2. #162
    Jul 2010
    the 1st time i put it in, ignition was off. put it in, however the rns510 turns off after 15mins, to preserve the battery.
    so i left it in there overnight, hoping it would continue. next morning, disc is still in there.
    while driving, with the above screen, i press notify - but i get no notification. that's because it keeps looping back to the start, when nears the end of the process.
    i don't get any errors.
    maybe i should try burning another disc and give that a go.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  3. #163
    Hmm my Passat stayed on for well over an hour while I updated the Firmware and likewise a few months ago when I put 18gig of music on the HDD.
    To burn my disc I used IMGBurn at 4spd on a DVD+R Did it perfectly Burned another disc and it was readable as well. So I have a spare.
    It will run off the disc In fact when I put mine in it asked if I wanted to do that The map version is 7920.
  4. #164
    Jul 2010
    its all good now.
    new dvd did the trick. took less than 5 mins to complete the process. got the notification to eject the dvd, and validated the new maps.
    on inspecting the 1st dvd i burned, i noticed a discolored spot on the outside of the burnt track - this must've confused it during the download process, causing it loop.
    good to c the speed limits correctly displayed as 110 km/h, instead of 120 with v5 maps.
  5. #165
    Jul 2010
    Problem now is seeing a lot of 50km showing as 60km.
    MY11 Tiguan 147TSI (SOLD)
  6. #166
    Jan 2012
    checked, I have the male voice available so I do have the latest firmware!
    why do people worry about the speed zones being right? in NSW, they change as frequently as traffic lights!
    I believe the speed is to estimate your travel time during processing your route.
    if you want the correct speed, look at the speed signs on the side of the road
  7. #167
    Quote Originally Posted by zei20t View Post
    A bit hard to see some speed signs when behind trees to aid the speed cameras that are out to get you Would be nice to have them correct on the screen of a multi thousand $ unit when a $150 unit can manage to include them correctly
  8. #168
    Apr 2011
    Just updated from V5 to V6 all went smooth however map no longer displays street names, any ideas? I'm running FW3810.
  9. #169
    Jun 2012
    Maroochydore, QLD
    RSN 850 MMI 3G & on-line activation solution www.JKU.com.au
    Hey mate,
    We have newly released MMI 3G maps for Touareg for 2013 together with online activation solution
    They are not the maps 5.4.3 released July 2012 but completely new 2013 released a week ago. As far as we know the dealers dont have online activation code for them yet.
    We can install in Maroochydore if you are this way - workshop only item.
    It will cost you $250 for the maps on 32 SD Card (not supplied) plus activation in the workshop $50
    Price dont include GST
    Quote Originally Posted by Flipper Dog View Post
    Interesting.....finally at the dealers now.
    Just got off the phone with VW Australia on Monday trying to have V6 maps loaded on an RNS850 (Touareg) Sat Nav to no avail. Not just a case of sticking in the disc and following promps, need an activation code of which (surprise, surprise) VW Australia have no knowledge of.
    Was asked on why I need my maps updated anyway if the current ones work aright????? When questioned them on likely pricing they stated that there was no fixed/standard price, so $60 sounds good if it is actually version 6.
  10. #170
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by liquidforce View Post
    Hey mate,
    Would that be the 7P6 051 236 D (T1000-20273) SD Card - Volkswagen Navigation AV Multi Region Map 1 (V3) or is there a newer version?
    Also anyone in Sydney able to load them or do I need an excuse to travel to the Sunshire Coast
    Flipper Dog
    Now - T-Roc R, Audi Q5
