Not unless you have had it loaded very recently
Printable View
For some reason I can't open page 8 , any one know why .?
You arent missing much but some chat but try this
http://www.vwwatercooled.com.au/foru...s-82963-8.html
Are you at work? Might be some text that flags the page as naughty on your proxy server
The male voice is found here
Setup/setup/language
IF you have Firmware 4120 it will give English and below it English(male)
thanks!
im pretty sure I did the upgrade, got radio text as well with that one IIRC?
All fixed some how it would only allow me to open page 7 once I posted it was ok ??
hmmm.....mine won't save to the hdd.
it keeps going through the download process.
its been almost a week now, including a 3+3hr drive.
car has had plenty of time to copy it, instead it gets to the end of the download process, then simply restarts the "download".
when i attempt to remove the dvd, i get the message saying that the download is in process.
if i do actually remove it, then it will ask me to insert the dvd navigation cd.
going through the setup menu, it says i have 79xx maps.
weird!!!
maybe i should start the car with the navigation dvd not inside?!??!
http://www.vwwatercooled.com.au/foru...9bd4d2a2-1.jpg
