"All works now perfect. Problem was no GPS signal in garage"
Seems it did !!!!!! Maybe
Had same problem on mine and after 20mins outside the maps appeared However it had gone through the installation
It may pay the OP to check which version of maps are actually in it because it may well be the old version if as he said it didnt load the disc.
It could be it relocated itself and just loaded the old map when it set its location. May pay to reload the disc and see what happens.
Then do the reset as in the post previous
