How long does the maps take to install... As I now have no GPS? What am I doing wrong?
no idea what you are doing wrong......
unless, you tell us what you are doing, then we can dinetify if there are any errors with your methodology.
I insert the map DVD after a firmware update and just says loading navigation DVD then nothing happens. Is it installing to hdd? How wil I know when it's finished? No maps come up when u push maps only this pic....![]()
U might need to take it outside and let it find where it is.
What firmware did you update FROM
What did you update TO
How long did you wait for it to load
Mine took nearly an hour and it wont let you eject it unless its finished
If you watch the screen it tells you what its doing
IF you dont know what you are doing perhaps get someone who does to do it for you
If you answer the above questions you may get more informative help otherwise its like doing brain surgery with a blindfold and over the phone if you get what I mean
Upgraded to 3810a not sure what it was previously. Think will take car out of garage to see of that helps
Thanks hilly billy for your detailed reply![]()
To update maps, turn the RNS on (don't turn ignition on — IIRC, leave the key out), insert the DVD and just wait 'til it finishes.
If your first install didn't take, moving the car outside won't help — try the install again.
All works now perfect. Problem was no GPS signal in garage. Thanks heaps everyone
not 100% true.
Updating maps can be done with keys in/out, driving or parked up. Loading takes around 20 minutes. RNS needs to be reset < > + info after doing map upgrade, just to settle it all down and freshen up it's 'cache'.
Usually, the Nav component will take a short period of time to get it's first satellite lock-on. After that, it is generally quite quick.
