One question for you Transporter or for anyone who know:
How quick the battery go flat ???
R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
Thanks "readerr0r".
Be also aware that even though you have battery drain, the radio might turn itself off when the battery charge is low, thus you might just get an almost discharged battery.
132TSI Tiguan Allspace
Well the RCD310 is now installed in my MK5 and I'll be monitoring it overnight to see how the battery voltage goes.
I confirmed that the unit had the same standby current draw as the RCD500 but I figured the real test would be to leave it over night.
Good luck - I hope all will be OK for your battery.
Hooray. No flat battery. Lost 0.02v overnight which is not really much considering temperature variation the battery would have seen. That was over 10hrs. I guess the real test is 48hrs!
Any pics installed day or night shoot ???
