Results 1 to 10 of 18
Thread: Upgrade RCD-300 to RCD-310
    Apr 2008
    I have in my VW Golf Mk5 TDI '06 RCD-300 and recently bought RCD-310.
    Is it plug-n-play or do I need to do some upgrade (canbus...)?
    Thanks guys
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Aug 2011
    Quote Originally Posted by VW VR6 View Post
    Thanks guys
    Hey mate,
    I've done an upgrade for someone with an 05 TDI going to a RCD510 and from what I can tell you need the new gateway, but you could always give it a shot first and see if you have batt issues?
    You'll also need an antenna adapter cable.
    Good info here...
    Upgrading 2nd generation headunits (RCD 300, RCD 500, MFD2) to 3rd generation headunits (RCD 210, RCD 310, RNS 310, RNS 510, RCD 510) | my-gti.com
    Apr 2008
    OK
    Thanks so much for info.
    I think I will sell RCD 310 and keep RCD 300 and maybe just upgrade to RCD 300 mp3 version.
    Nov 2012
    QLD
    Hi, does your RCD310 have security coding?
    And is it the model able to have aux input, bluetooth media streaming etc?
    Apr 2008
    I just waiting to arrive from Sydney.
    Will PM you asap they arrive.
    And YES they have CODE/PIN.
    Adelaide hills, SA
    Quote Originally Posted by Tom87 View Post
    You could also upgrade to RCD510 with 6CD and SD card slot for just a little bit more.
    To find out if you need to upgrade the canbus, you need the VCDS scan of your car
    and then look in this thread Can Gateway upgrades (Battery drain fix after RNS, RCD units install) if yours could be upgraded, needs to be replaced or is OK to use.
    Mar 2009
    UMG Brisbane
    If you want to scan your car and find out whether you need to upgrade, PM me. Almost certain that you would.
    The physical upgrade itself is not that hard, but the coding of the gateway can cause issues. Jimmy said mine took a bit longer because it thought it was a LHD German Audi Diesel.
    If you are confident (having read the gateway upgrade procedure on My-GTi) then you can borrow the VCDS cable for coding
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Nov 2012
    QLD
    Mine's a late 07, MY08 with full screen MFD and RCD300 MP3 (but no aux input). I gather this means it will have the newer gateway. If my gateway needs to be changed I might not bother with it at all as it really isn't that important to me.
    I like the look of the RCD510 but I think it is a touch excessive for what I want (I'd really just be happy with just an Aux in cable).
    Thanks for the offer 99_FGT.
    Nov 2012
    QLD
    Woo, checked the bus gateway the old fashioned way by pulling apart the dash.
    turns out my September 07 build MY08 (full height MFD) has the L revision gateway. yay.
    Adelaide hills, SA
    ...and now the real test. Fit the RCD510 and see if it the battery doesn't go flat.
