Make sure you take the dust cap off the lens if you haven't remembered to do that one already....
Otherwise I would be checking that you have power to the camera when you're in reverse gear. Check the voltage on the connectino to the camera. If you've taken a connection off the reverse wire make sure you've taken the positive rather than ground. I would sugest if you're not seeing anything that you may not have the power wired correctly.
If the screen is going black and you have lines then programming appears to be all OK. Just looks like you're not getting the image.
