Transporter T5 2012 Aftermarket radio antenna power.
Hi there
I note a lot of discussion about aftermarket radio etc problems to do with CANBUS. I do however only have a simple question.
Is the mirror preamp (antenna) power only activated by placing 12V on the coax inner (via a suitable adapter), or is there a CANBUS relay somewhere that is turned on when the processor sees that the radio is on.
TIA Bob
- You may not post replies
- You may not edit your posts
Forum Rules
