Results 1 to 3 of 3
Thread: Trailers with LED lights
    Feb 2010
    Coffs Harbour NSW
    I mentioned on a now closed thread that I had some adventures with changing my trailer lights from incandescent to led. I find that this problem is widely scattered but frequent news about the web.
    I did find that a company called Redarc makes a device part # LDLIBT12 that solves the problem - I rang Redarc and they directed me to several local auto-electricians. I rang one I knew and he priced the device for me: AUD$330.
    He thought that VW might be able to reprogram their towing harness electronics or resistors could be placed in parallel across the feeds/earth to fool the harness into thinking that it was dealing with incandescent bulbs.
    From other sites it seems that VW do have a solution by way of a European type plug but it does not always work satisfactorily. A call to a helpful workshop supervisor at the local VW dealer gave no hint of a VW solution and the harness could not be reprogrammed.
    I have now found that you can fit load resistors supplied by led autolamps across each function - these cost about $19 each. This problem seems to be widespread and is growing as more led lighting is installed in trailers. I figure that I can manage with three resistors with a bit of cunning - it seems cheaper than the packaged solution.
    Everyone seems to be falling into the pit by default, many auto-electricians and dealers seem unaware how to fix the problem but there seems to be an increasingly widespread awareness of a fix.
    ps: the problem? Led lights have less resistance than incandescent lamps and the modern car trailer loom circuitry thinks that a bulb has blown and a warning lamp comes on - not a big deal so far but the circuitry then flickers the leds every few seconds on all trailer lights leaving a crazy distraction for all who follow you on the road. The turn indicators, tail and stop lights? Well they seem to work anyway - but if you follow someone with rear trailer lights flashing in a low level way every few seconds then you know what the problem is.
    Fitting some resistors tomorrow - wish me luck.
    The best solution would be an in-house oem fix from VW - meanwhile incandescent lights are cheaper and a whole lot less bother even if they blow bulbs and generally rot away.
    Tom
    Jul 2011
    Barossa Valey SA
    Quote Originally Posted by Tom Caldwell View Post
    Tom
    So what happened?
    Feb 2009
    Sydney, Australia
    Look at the thread details... it's over a year old.
    The guy has 4 posts. If you look at his profile, they were all in 1 day, and he hasn't been back since... you're not going to get any reply
