9W7 Install not working
Hi guys,
So I've just installed a 9W7 kit in my 2009 Tiguan. The module is above the climatronic and plugged in. I had a DIY harness which I have spliced as per this pic. I have plugged into the BT module, the mic and the RNS510.
Now, the RNS-510 powers on fine and works as previously.
I go into VCDS, 77 - Telephone is already checked in Installations for CAN Gateway.
But I can't go into the Telephone module in VCDS. It isn't picking it up for some reason.
Is there any way to trouble shoot here? I'll jump in with a multi-meter tomorrow and make sure my solders are good. I can obviously check the power+ and gnd but is there a voltage CAN +/- will throw out or a way to check?
Tips appreciated please.
Cam.
- You may not post replies
- You may not edit your posts
Forum Rules
