I thought composite video was on standard wire - not 50 or 75 ohm coax.
not saying you can't use the antenna cable, but you will need to cut and put on the correct (RCA) connector for the video at the head unit, and presumably ground the shield, and do the same at the other end.
Agree with Kamold - run the wire, yes it is a PITA but it is probably not that much more work than what I've described above. Plus you need to run a 12V source for the camera too (but you can do that from the tailgate power socket though) and tap the reverse light wire as well.
Al..
2013 MY13.5 Passat V6 Highline Wagon. Watch this space
GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
