Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Tiguan aftermarket reverse camera
    Jun 2009
    Awesome!
    Thanks for the info.
    I'll see if i can get some info on a good camera.
    If it is hooked up to a relay form the reverse light it should turn itself on when reverse is selected?
    Jan 2008
    Quote Originally Posted by team_v View Post
    Hi guys,
    I was having a browse on ebay today and saw that they now offer a wireless reverse camera.
    I understand that Kufatec sell a harness that allows AV input into the RNS510.
    Is there a website that sells this and can anyone point out what part number etc i need?
    Aslo, the TV system is NTSC but they advise you can contact them if you need a PAL.
    I assume we would need the PAL version?
    Kufatec supports NTSC however PAL does work depending on the revision.
    And I wouldn't touch the Kufatec interfaces after the problems I and others had with them with the RNS 510's, at times I was lucky if it switched on 20% of the time when I reversed. Support for future firmware updates to the head unit is questionable, the operation of the unit was poor (images would start up in colour or black and white depending on the mood) and there were numerous other problems.
    Steer clear or you'll be pulling your hair out and wasting a lot of time on trying to sort it out.
    Jun 2009
    Quote Originally Posted by Maverick View Post
    Thanks for the info Mav.
    I was hoping you would chime in since you have been through most of this process.
    Do Vw have a harness that allows AV input?
    Or is there an aftermarket alternative that does work?
