Kufatec supports NTSC however PAL does work depending on the revision.
And I wouldn't touch the Kufatec interfaces after the problems I and others had with them with the RNS 510's, at times I was lucky if it switched on 20% of the time when I reversed. Support for future firmware updates to the head unit is questionable, the operation of the unit was poor (images would start up in colour or black and white depending on the mood) and there were numerous other problems.
Steer clear or you'll be pulling your hair out and wasting a lot of time on trying to sort it out.
