Results 1 to 10 of 14
Thread: T10 LED Parker issues
    Oct 2016
    Hey Guys,
    can one help me with T10 LED parker conversion in an R36?
    this is the 3rd set i have bought and none of them are working and they are supposed to be CANBUS... its not the fuse as putting a standard filament globe back in works.
    i have checked for polarity by turning them, that obviously didn't work. and put them in my forester and they all work no issues.
    Attached Thumbnails Attached Thumbnails T10 LED Parker issues-dsc_0241-jpg
    Mar 2015
    perth wa
    Have you tried them inside the headlight or just wires hanging outside ?
    Sent from my SM-G935F using Tapatalk
    Dec 2008
    Sydney/Canberra
    Are you getting bulb errors with them installed?
    Oct 2016
    i fail to see how that has anything to do with it. there is no interlock on the cap. and the normal globes work outside the housing too.
    Oct 2016
    Quote Originally Posted by Umai Naa!! View Post
    yes still getting errors.
    Oct 2016
    is there a way to test if the bulbs are actually CANBUS?
    maybe i've been getting duped by unethical sellers and buying products that aren't actually CANBUS
    Dec 2008
    Sydney/Canberra
    When you're changing polarity, are you cycling the key and the headlight switch to clear the errors?
    Oct 2016
    By cycling the key you mean taking the key out then turning the bulb around then putting the key back in? Then yes. Even trying it with the key out and cycling the switch.
    The original ones can on then went out after 5 seconds or so but these ones don't come on at all.
    Dont buy ebay LED's. If you want good quality LED's that work in VW's without giving errors, look at Bold Sport bold-sport
    Bowral, NSW
    These do not appear to be CANBUS compatible.
    CANBUS compatible simply means the units have resistors on them, to simulate the larger power draw of a conventional globe.
    You'll be able to tell, as a real CANBUS compatible globe will also be covered in heatsinks; and look a lot different.
    LED globes have a certain polarity, too - make sure you have them the right way around. (If they work; they're the right way around)
    I have LED indicators in my Octavia's headlights; and LED reverse lights in the tail lights. My tail lights are also aftermarket fully LED units and work perfectly, and do not produce errors - but that being said; they have huge resistors on them to trick the car into thinking that its still running the incandescents.
    Please see the below image; you can easily see how much more "substantial" the globe looks, because of all the added heatsinks (for heat dissipation)
    This is what you will need.
    T10 LED Parker issues-car-auto-font-b-led-b-font-t10-194-w5w-font-b-canbus-b-font-10-jpg
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
