Results 1 to 6 of 6
Thread: sub 10" cuts out
    Mar 2009
    sub 10" cuts out
    Hey I have a 10" sub in box running on a 2400 watt mono block digital amp certain songs or if turn up too loud sub cuts out now the sub box is not specifically made for sub would thay be the problem? If I pull car over turn off then turn back on sub kicks back in any help would be great cheers
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by passat08 View Post
    Hey I have a 10" sub in box running on a 2400 watt mono block digital amp. Certain songs or if turn up too loud sub cuts out now.
    The sub box is not specifically made for sub. Would that be the problem? If I pull car over turn off then turn back on sub kicks back in. Any help would be great.
    Some form of protection is tripping in the amp which requires the power down to reset. Has it always done this? What brand/model is the amp?
    It is unlikely that the enclosure has anything to do with the issue - at worst, an oversized sealed or poorly matched ported enclosure could lead to the sub driver bottoming out.
    Resident grumpy old fart
    Mar 2009
    Schneider amp lightning audio sub
    Aug 2013
    mudgee, nsw
    sub 10" cuts out
    Like above, sounds like amp protection. Try turning the amp gain control down a bit at the same volume
    Sent from my iPhone using Tapatalk - now Free
    2010 POLO 77TSI COMFORTLINE, CANDY WHITE, H&R 30/50 sport cup kit, 18x8 lenso speed 3
    2016 SKODA RS230 WAGON, MOON WHITE, TECH,TAILGATE, P/ROOF, HP UPGRADED CLUTCH, JB4, DTE PEDAL BOX, EIBACH SPORTLINES, AVID1 18X8.5 AV20'S, CTS TMD/TIP, 034 DOGBONE INSERT, OBD11 MODS
    Mar 2009
    Ok cheers
    Oct 2012
    Melbourne, Victoria
    I was going to suggest protection mode as well. What was your amp rated at in RMS? Ditto for the sub. I have a feeling it's significantly lower than 2400.
    Additionally, you might want to check and make sure you've grounded properly. Sometimes you might even need to rough the spot up with sandpaper so that there's a good connection to the chassis.
    Is the amp hot to touch at all straight after it cuts out?
    Biscay Blue Volkswagen R36 MY09
