Results 1 to 9 of 9
Thread: Stopping reverse camera screen on RCD510
    Dec 2009
    I've just had an RCD510 system installed in my Polo to replace the RCD310.
    The RCD510 was taken out of a 2010 Golf GTI.
    Problem is, when I go into reverse, the screen goes blue because it expects a rear vision camera.
    The guys at the VW dealer that installed the 510 couldn't fix it.
    Am I wrong in thinking it should be easy to change this if you know where the right setting is?
    Oct 2009
    From memory, you will need to connect up to a Vagcom, go to gateway 19 and untick the backup camera box.
    If you don't know what I am talking about, you will need to take it to either a dealer or somebody that has access to a Vagcom.
    Jan 2008
    Quote Originally Posted by BlackSuperb View Post
    This only applied to cars with a dedicated camera controller like the Passat.
    Jan 2008
    Quote Originally Posted by Jetta5 View Post
    No but remember the dealers have a different tool that shows them different information.
    Installing a Golf Mark VI Rear View Camera (RVC) into a Golf Mark V
    Programming Head Unit
    Using Vagcom/VCDS the headunit requires programming to tell it of the existence of a RVC.
    Connect to controller 37 and in long coding under Byte 3 select Bit 6.
    To complete the programming reboot the RNS 510.
    Oct 2009
    Quote Originally Posted by Maverick View Post
    Ahh, I see. Thanks for that.
    It also applies to a Columbus Nav that is in a Superb.
    Dec 2009
    Excellent info, thanks. I don't have a vagcom, so I'm getting my dealer to do it.
    When you say that the dealers have a different tool, does that mean those instructions do or don't apply to what a dealer will see?
    When you talk about Bit 6, does that mean to disable the RVC you would "unselect" Bit 6?
    Apr 2010
    Sydney,NSW
    Why not fit a camera? It is extremely useful, I have one on my Bora.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Jan 2008
    The instructions should be enough for the dealer to follow, all they need to do is to connect to the head unit and they'll find it soon enough (it will be easy to follow as it will be a menu item now since the mark 6's have RVC's in Australia). If it wasn't a menu item they would have had to have manually changed the setting "blind".
    Their tool is differnt in how it operates, Vagcom/VCDS is designed to show you everything at once, the dealer tool is setup more around functions with common used ones at the top and drilling down for less common ones.
    And yes I mean deselect bit 6 under byte 3.
    Ooops: The instructions I gave are for the RNS 510 but will be similar for the RCD 510. I'll check to see if I can find the correct settings tonight.
    Dec 2009
    Thanks Maverick. Appreciate that. Also - my car is a new Polo, so may not be configured the same way as the Golf.
