Results 1 to 10 of 20
Thread: Is this the standard stereo on a mark 6 golf?
    Giving up trying to get a new golf for the price i want, in the colour i want, with the specs i want. I'm thinking i will just buy a cheaper on and fit an rns510 after. Is this the standard stereo? Meaning i will need lots of bits i.e. rns, bluetooth module, aerials, mic, rvc, etc, etc....
    Apr 2010
    Yep, that's where I started and I now have RNS, BT, MDI, RVC, etc. Installation guides available via http://tinyurl.com/vwstuff
    Parts available from ebay and carsystems.eu
    Apr 2010
    Man I'm so close I can almost taste it. I'm down to two cars: a base model manual or a slightly used demo with all the fruit, DSG, Sat Nav, Leather. Problem is while I was set on the manual I'm now leaning towards the DSG after reading and watching a heap of reviews. $5,000 difference in price though which woud go a long way to putting Sat Nav, etc in the base one. But it's hard to find a DSG, with Sat nav in my colour/price range.
    Apr 2010
    Well DSG and leather are worth more than $5k on their own and a bit harder to retrofit...
    DSG - $2500
    Leather - $3000-$3500 ?
    RNS510 - $2000 from factory
    Just be sure to test the DSG out in stop/start traffic and uphill and look for any shudders that might indicate a bad clutch pack/mechatronics that needs to be replaced under dealer warranty if it's a 7 speed one. 6 speed DSG is older tech and smoother, but costs a few $hundred more to service at 60,000kms.
    I hear ya. I didn't know that about the 7 speed. I though the DSG issues had been sorted from 2010 onwards. I'll definitely try to flog it on the test drive.
    Apr 2010
    I think from MY11 onwards they've been ok, or no-one's mentioned the problem yet. Rarely a problem with high speed driving, just start/stop changes between 1st and 2nd gear where the car in front moves unpredictably.
    OK, now I know you guys are good (Ryan?) what is this then?
    and can I put a RNS510 in there imstead?
    Jun 2011
    That's an RCD-300 from a Golf 5 AFAIK. You can fit an RNS-510 but you may run into battery drain issues - all depends on what version CAN-Bus you have, take a look here:
    Can Gateway upgrades (Battery drain fix after RNS, RCD units install)
    Apr 2008
    That is NOT RCD-300, that is RCD-500 6cd mp3 player
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
