Results 1 to 7 of 7
Thread: Second Hand RCD 300.. Can i get one and simply plug and play
    Jul 2013
    Hey All,
    As the title states, I'm after a second hand RCD 300. I'm not going to look at a rcd 310 or above, the reason being i need to sell my car and my current unit is very badly worn.
    I've sourced one from a wrecker (for $150 ) but i've now been told units wont work in other cars due to its programming? They can confirm i would receive the code in purchase.
    Does this sound right?
    Cheers,
    Matt.
    Dec 2008
    Sydney/Canberra
    It'll work, but you need the connectors off the antanna cables as well.
    If they don't supply you the radio code, take your VIN and the serial number off the radio to your local dealership, and they'll get it off the database for you.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Pacific Paradise QLD
    Thats a bit too much Look around, have seen RCD 310 for $50 (NOT 300 ) which is an older model
    Look here heaps of them http://www.gumtree.com.au/s-ad/green...ode/1017063665
    http://www.gumtree.com.au/s-audio-gp...d+310/k0c18473
    Or this one even with postage would be cheap http://www.gumtree.com.au/s-ad/keper...tem/1016225692
    Aug 2011
    You'll need the code if it has not been installed in the car before. No programming will be required.
    If you get an RCD 310 and have a MY07 or earlier, you will need a CANBUS upgrade.
    If you want, i have 2 x RCD300 here (1xMp3 and 1xNo Mp3). I can sell you a unit and install if you like.
    Jul 2013
    Quote Originally Posted by lankfert View Post
    Hey mate,
    I've sent you a pm
    May 2009
    Townsville,QLD
    Send me a pic of the unit, if its the same as what I have you can have it. I'm coming to Melb next week and you can pick up.
    Quote Originally Posted by vmj386 View Post
    Hey All,
    Cheers,
    Matt.
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
    Jul 2013
    Quote Originally Posted by BrettD View Post
    Hey mate,
    The unit looks like this: 3469d1328521572-rcd-310-vw-rcd300.jpg
