Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Samsung Galaxy and Tiguan Bluetooth
    Sep 2011
    Quote Originally Posted by mfl View Post
    In my case, the Samsung Galaxy Ace, would drop out in certain areas, and while it was still visible in the MFD, it would not reconnect, unless I turned the engine off (switching off the bt module). The HTC doesn't drop out, it just doesn't connect in the first instance.
    Also on the MFD, I only get the bluetooth symbol, and blank squares. no battery strength or audio, although the phones will stream music.
    I know HTC left a very old bluetooth module in for the HTC Incredible S and did not take the upgrade, people have been having issues connecting to BMW / Audi bluetooth modules with HTC:
    Droid Incredible’s Bluetooth Having Problems Connecting To Cars, Keyboards And More | Gizmodo Australia
    Having Bluetooth issues? Details: - DROID INCREDIBLE by HTC (Verizon) - Android Forums - HTC Community
    Some developers have made their own HID drivers for Android phones without the upgrade, however cant find anyhting for HTC...
    Apr 2010
    Perth, WA
    Quote Originally Posted by haggis View Post
    Peteaussi when this happens is the phone searchable through the MDF display?
    Nope.. I try to search for it but it can't connect to the phone. I usually turn the car off or restart my phone. One or the other typically works.
    2008 Mk5 Golf .:R32/ BMP/ RCD-510/ More to come
    Apr 2011
    I have a GS2 runs perfectly with new Tiguan RNS 510 and bluetooth, either the MDF display or the RNS display. What Firmware are you running on the GS2, I run 2.3.3? Do you have any other devices in the car which pair or can pair with your phone? Is your GF's phone running bluetooth at the same time? From the MDF screen when it does not conenct is it searchable?
    D] Hi mate, Does your phone book load, as mine connects and makes calls but I get a error msg saying unable to load phone book.
    Anyone have any tips?
    Rising Blue, Golf R 5 dr, DSG, 19" Silver Talladegas, RNS-510, Leather, Sunroof, B/T & MDI
    Sep 2011
    Quote Originally Posted by Biodif View Post
    Yep phone book loads both on RNS and MFD screen, couple of things;
    1/ Are you using the standard android/samsung phone book? Or one of those personal assistant apps which manage this stuff? I am using the standard one
    2/ Running Android 2.3.3
    3/ Do you have administrators configured on your phone? I do not use this as have found issues with this and bluetooth on my PC.
    4/ Disable any power saving or power saving apps, just use the 'notification slide down' to enabel disable wifi, blueooth, gps etc.
    Apr 2011
    1)Standard android/samsung phone book
    2)Running Android 2.2 (cant get gingerbread yet. But I tried the bluetooth on my sisters Galaxy 2 which is on gingerbread and the car would not even detect her phone)
    3)No administrators on the phone
    4)All power savings apps disabled
    Tried again this afternoon, first it connected, could access phone book through MFD. I called the phone, no problems, went through the cars bluetooth, could see it on both the RNS and MFD (great I think!) then I tried to make a call accessing the phones phone book through the car - 'Call failed'. So I try making a call by pressing the buttons on the phone, calls fine, but does not go through the car bluetooth (I do the same think on my Nokia and it DOES go through the car bluetooth, even when dialed from the phone directly). Try calling the samsung again, call goes through to phone, even though its connected to the car (and I still have access to the phone book). I disconnect, turn car off and on again, this time it wont even detect the samsung!
    Jul 2009
    My Samsung Galaxy Ace is running Gingerbread and the Phone Book refuses to download. Car is latest model Passat with RNS510. iPhone4 used to work perfectly but the Android is giving me a headache.
    It connects most of the time (but not all of the time) to allow me to use the Bluetooth in a basic way but not once has it allowed Phone Book download.
    Mar 2010
    reservoir, vic
    I just bought a Samsung S11 today and same problem.It will not download the phone book...tried copying numbers from sim card to phone and still no good... I hope someone can figure this out as my Nokia N97 mini worked fine.. I have the Kufatek Fiscon hands free kit installed... the MFD worked great.... I should have checked here for problems first...LOL
    MY08 Passat 125TDI sedan.leather.Xenons..Dynaudio.Satnav.. RNS 510
    Mar 2012
    Similar deal here: 2012 Tiguan w factory BT paired with Samsung Galaxy S2, stock Contacts software, no Admin accounts (not even sure what that means). Bluetooth connects fine, can play podcasts, music no probs, & can dial calls out/receive calls, but won't download phone book. Android 2.3.3
    Don't have any answers, just thought I'd add to the roster of folk with this problem.
    Mar 2010
    reservoir, vic
    Don't know if this will help anyone, But I changed my firmware and maps as per this thread and when I got to pairing my phone, The phonebook downloaded....
    http://www.vwwatercooled.org.au/foru...t0r-65337.html
    Mar 2012
    Damn i am not liking the sound of this....
    I have a Nokia N900 and it works faultlessly.
    I wanted to move to Telstra and get a HTC Velocity 4G but it sounds like i am going to end up stuck with the iPhone 4S which i really didnt want
