Results 1 to 10 of 20
Thread: Samsung Galaxy on MDi
    Jan 2010
    switched over from iphone. how does samsung galaxy connect to the MDI?
    and can i control all the songs like in iphone.
    Apr 2010
    I would imagine you just connect your USB to Micro USB cable into the MDI and then connect that to the phone.
    You'll need this adapter though:
    HQRP MDI MEDIA-IN USB Adapter Cable fits Volkswagen VW Jetta Golf GTI Passat | eBay
    Bluetooth audio streaming might be easier if you have that option in the car.
    Jul 2005
    doesnt that cable come with the mdi??
    I have 2 cables with mine... one to connect to iphone and the one to connect to usb.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Jan 2010
    but does it connect to galaxy properly? allowing to scroll through songs?
    Quote Originally Posted by blutopless2 View Post
    Dec 2010
    Plug your phone in using the appropriate cable (the USB one).
    On your phone, go to Settings -> Wifi and Network -> USB Utilities -> Connect Storage to PC
    You should be able to browse the music on your phone like it's standard USB storage.
    I'm just taking a guess here.
    I don't have an Android phone.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
    Apr 2010
    Some people opt for one cable and some just get what they're given. Usually depends on the dealer.
    Should work fine if the phone connects as a Mass Storage class device. Either it will work 100% with all the scrolling features or it won't work at all. There might be a setting you have to change as mentioned ^ but I'm confident it'll be fine. If I get a chance & if I remember to bring the cable I'll see if my S2 running ICS plays nice with it. Since I have the RNS510 all my music is already on the car's HDD so no need to use the phone.
    Jan 2012
    Epping, NSW
    I couldn't get my sgs2 to show up the option of the cable connected (I use debug mode and select mass storage if I want to connect to a PC) so the mdi is a glorified phone charger for me (Bluetooth streaming works fine).
    I have two cables as well, the normal MDI -> Standard USB head and the MDI -> iPhone which I had been using more a less to charge the iPhone and managing my playlist normally to stream via bluetooth on the RCD unit.
    I've purchased a spare USB micro USB cable as I've recently purchased a Samsung Galaxy S3, which currently has no issues syncing via bluetooth to my RCD either, USB functionality not tested tho.
    I find operating music via the MDI to be frustrating and slow, it's a lot quicker to access on your phone which just streams via BT
    Current: 11' MY12 VW Golf GTI 5DR 6MT | Tornado Red
    Previous: 06' MY07 Subaru Liberty GT Spec.B 6MT | 04' Honda Euro Lux 6MT | 99' MY2K Chrysler Neon
    Apr 2010
    Do you only stream via the built in Music player or can you also stream with other apps such as TuneIn Radio (Internet), BeyondPod (podcasts), PowerAmp, etc?
    Apr 2010
    Did a quick test at lunch time. If you just plug in the S2 (ICS) at press the MDI button it won't work. Before you connect the USB cable you have to Settings, More, USB Utilities, Connect storage to PC and so on. I was then able to listen to music on my MicroSD card on the phone (couldn't browse the Internal storage, not sure if this would be different if I didn't have a SD card). All tracks/folders listed fine on the RNS510 and wheel controls worked.
    If I really wanted to I could use MDI but it's not really something I'd use often. Plus I already have a USB stick with loads of additional music on it, and I can copy files from my S2 to the USB stick using a $2 adapter like this one: eBay Australia: Buy new & used fashion, electronics & home d
