Results 11 to 20 of 30
Thread: Roof Console - Three-Button Module - Reprogram
    Melbourne, VIC
    I've tried to do it through VCDS, found the string (can't remember where it is...) but it asks for the new number in 16 digit hexadecimal or something, but it didn't accept the Australian toll-free number as a replacement value. I gave up after about 5 minutes, but I'm happy to go hunting for the location again if someone else wants to play with it
    edit: after reading the OP again, maybe we could all just copy the coding that's on his Passat if you can organise to hook it up to a laptop?
    Golf R - 5dr Rising Blue, DSG
    brisbane
    this should be set up when the vehicle is PDIed and can be changed via adaption channels in the phone control unit 77 should be set to vw assist and I button to your local dealer/selling dealer will find out the actual adaption values tomorro
    Jul 2011
    Berwick, Vic
    That would be great, thanks mate.
    Feb 2009
    Sydney, Australia
    Thanks bushnut. I must say that this is one of those things which the dealers miss very often.
    Jul 2011
    I've checked around if it can be done to mine and i don't think the three buttons will function for service calls like in europe,
    coding or adapting different numbers can be done you could possibly store a workshop number or nrma road service it will call through
    your own phone. Thats about it!!!
    Jul 2011
    BOTANY
    Changing VW ASSISTANCE and VW INFO phone number when INFO/SPANNER button is pressed
    Does anyone know if it is possible to change the number that is dialled when you press and hold the the INFO or SPANNER button on the roof console. It is meant to dial VW ASSISTANCE and VW INFO but it is programmed to dial a german phone number 008008655792436.
    Can we re-program these buttons using VCDS ?
    Thanks in advance
    Melbourne, VIC
    see this thread, still waiting on bushnut to get back to us
    Jul 2011
    If you have VCDS select installation list, then select phone channel 77, then select adaption, then scroll down and find the channels
    written in text (emergency numbers) and (information) change these to a number you want then press ok. This will only work when your
    own phone is connected via bluetooth and will dial the number through your phone only. It will not work if no phone is connected.
    Be careful and don't change anything else accidently there are a lot of other adaptions!! otherwise trip to dealership to recode may be
    required
    Feb 2009
    Sydney, Australia
    Thanks grtuned
    Now, if a few people can test this and report back on their car model types and years (e.g., MK6 Golf GTI MY11.5 etc). Cheers.
    Jul 2011
    BOTANY
    It ask to enter the phone number as a 7 hexadecimal numbers separated by a space. Anyone know how to convert aussie phone number to hexadecimal. eg. 0411 222333 to xx xx xx xx xx xx xx.
    Thanks.
