The RNS510 is a great unit and unlike the MFD2, because it is still the current Sat Nav option from VW you are still able to access map upgrades as road developments progress. It will depend on what model your car is as well as to whether or not you would need to change the CANBUS (Controller area network - Wikipedia, the free encyclopedia) or you will more than likely suffer the battery power drain issue that many others have encountered. As a rough guide pretty much any model pre and including 2007 build date as I understand. For further info try visiting "Mavericks" website - RNS 510 | my-gti.com
Reason: fix error
Russ
2005 Subaru Outback 3.0 R Premium
