Results 1 to 10 of 14
Thread: RNS510 version
    Jan 2011
    Factory Fitted RNS510 Question
    Hi there, I have an MY11.5 Golf R that has the RNS510 factory fitted unit. I just tried to use a 16GB SDHC card and it didn't work, so I started questioning whether I had the latest firmware/hardware version of this. I also noticed that the latest firmware of the RNS510 shows speed limits on the SatNav which mine doesn't do, so further evidence that I may not have the latest - seems a bit strange seeing as mine would have rolled off the production line around November / December time?
    Is there an easy way to check the version, and if I am a downgraded level, is it straight forward to sort out?
    Thanks.
    Last edited by orkers; 16-05-2011 at 10:20 AM. Reason: Corrected errors, modified title for relevance
    MY11.5 Golf R - Candy White 5 door - still giggling like a child when I drive it!
    Adelaide hills, SA
    Just search through the existing threads, I'm sure that there are threads with the similar question. From my memory SD card has to be properly formated and try to put your songs in SD card root directory (no folders) just to test it. I use 2GB SD card in our RCD510 it worked right from the start.
    Maybe some one with more knowledge can help out here.
    Quote Originally Posted by orkers View Post
    Thanks.
    Have you got the star button on the top right of the unit ?
    I pulled mine out to install a bluetooth behind it and the build date on mine was Feb 11 - so brand new.
    I put a 32Gb in and it played fine - but you have to follow the instructions for folder naming - otherwise it wont recognise any content.
    love your signature - "still giggling like a child when I drive it!" - Im the same and I've 'just' got the Polo TSI
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Feb 2009
    NSW
    I have just been notified that there is an RNS510 update in a few months.
    Quote Originally Posted by ozgti View Post
    As in an update with the RNS unit or the firmware
    Feb 2009
    NSW
    unit. software update
    Nov 2009
    Unit == hardware. Firmware = software. So we're talking the firmware, right?
    do tell more...
    Jan 2011
    Quote Originally Posted by 77kw polo TSi View Post
    Yep, mine has the star button on it. I suspect the unit is up to date, but it might be my SDCard that is the issue - I bought the fastest one possible which is a Kingston class 10 (100x). I tried it with just one song in the root folder and nothing else (including a clean format to FAT32) but still didn't recognise the SD. In fact, if I tried to start up the RNS510 with the SD card in it, the MEDIA component of the RNS510 would just say "system is starting" and would hang.
    Glad to hear there is a new firmware/software/update thingy in the pipeline, would love to see a few enhancements, although I now understand that some of the limitations are down to the crap maps from Australia, such as the lack of support for showing the speed limits and no speed camera info etc.
    Yep, my signature certainly rings true - I have never had som much fun in a car before, well not since being married anyway
    ...In fact, if I tried to start up the RNS510 with the SD card in it, the MEDIA component of the RNS510 would just say "system is starting" and would hang...
    yip - that doesnt sound right, but everything else does - I've got a branded SD card, cant remember the make, and it seems to play fine. maybe buy a cheapo basic just to try it out...
