Results 1 to 10 of 14
Thread: RNS510 + Scirocco R + Video on Motion Hack
    Sep 2011
    Melbourne,VIC
    Has anybody tried getting the video in motion working on the latest RNS510s on the Rocco? Here are my model details.
    http://dl.dropbox.com/u/40180426/RNS%20VERSION.JPG
    Just reading through the forums the Berto89 hack seem to be failing on most later model RNS units
    I got a 'software downgrade error' when using the following guide + iso.
    http://www.vwwatercooled.org.au/foru...n-47191-2.html
    2012 - Scirocco R Candy White DSG , Sunroof + GPS.
    NT
    I am hearing you...I got a stack of dead CD and DVD from trying different burn speeds etc...
    Sep 2011
    Melbourne,VIC
    I'm pretty game to try this but the iso download is taking forever - will take a few days at this rate . http://www.vwwatercooled.org.au/foru...c12-69771.html
    Apr 2012
    Kellyville, NSW
    EDIT: Files are live on my Dropbox... as long as the links don't get hammered (ie max 20gig per link per day) they won't disable the links - so be nice and don't share the link from here .
    4020 Firmware (from here) DOWNLOAD 548Mb ZIP
    V5 Map Data (from here) DOWNLOAD 501Mb ZIP
    Unofficial Recovery Disc (from here) DOWNLOAD 3.9Mb ISO
    BTW - if this isn't allowed for some reason, let me know and I'll remove. Also I take no responsibility for anything... they are just the files from the other forum posts listed.
    Thanks,
    Shane.
    May 2010
    Charters Towers, QLD
    Apr 2010
    Perhaps investigate which file to edit on the Berto CD so that you can change it's version number so that it's slightly higher than your current version.
    Otherwise upgrading the entire firmware to version 4x (as posted above) would be the easiest (cheapest) way.
    Sep 2011
    Melbourne,VIC
    So an update to this - firmware installed correctly but I cant seem to get the map data to work - always fails to read the DVD I burn. And I know I'm burning the ISO correctly because it worked when I was on 3790 moving up to V5 of maps.... but now with the new firmware (4020) I can't get the system to read my DVDs to install the maps (they are a different brand tho? Still DVD-R)
    May 2010
    Quite finicky installing these things. Try a CDR instead of a DVD. Burn as slow as possible.
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
    Sep 2011
    Melbourne,VIC
    Yep just tried burning another dvd same as before - but worked this time - weird..... oh well.
    I Can confirm the above files and process works with the Scirocco R RNS units.
    Jun 2007
    South West WA
    Yes, I also can confirm that burning a DVD at 2x on a Mac in Disk Utility updated my RNS510 "F" without problem - took a hour...
